Wheel Bearing - Front - How do I change it?
Posted: Thu Sep 09, 2004 2:25 am
by TheTwins
How do I remove the the front wheel bearing to change it? Any special tricks I need to know?
Re: Wheel Bearing - Front - How do I change it? (TheTwins)
Posted: Thu Sep 09, 2004 3:36 am
by futseal04
How may miles do you have? Even if they are sealed bearings (and I don't know if they are), they should last at least 100K. If they aren't sealed, then you should be able to repack them. At any rate, when you do it, take a look at your brake pads to make sure they are OK.
Posted: Thu Sep 09, 2004 10:04 am
by NovaResource2
Yeah, why. They are sealed and like was said, should last 100K miles (or more). To remove one you need to remove the wheel, remove the caliper, remove the rotor, remove the large nut in the center of the axle, remove a few bolts (3 or 4 via a hole in the wheel stud mounting surface), remove the bearing. Reverse to install.
Posted: Thu Sep 09, 2004 11:55 am
by champcaracing
your going to need a press to get it apart and to press everything in. also when you remove the axle nut, MAKE SURE you get the one side that is notched down on the axle up all the way or your going to F@#k you axle up.i know i thought i had a couple of those chesialed (SP?) up and screwed the axle up.
