Proper Leather Care
Posted: Thu Jun 06, 2002 3:01 am
by d_m_kolb
The products found in this artical can be found at Classic Motoring Accessories. http://www.properautocare.com Leather should be routinely cleaned using a ph-balanced, non alkaline cleaner such as Lexol Leather Cleaner or Pinnacle Leather & Vinyl Cleaner. Cleaners loosen and lift grease and grime (like French Fry fingerprints) without drying the leather or affecting the hides natural ph.To properly clean leather:Spray cleaner to a wet applicator pad and apply to one area at a time (i.e. a seat back). Gently agitate the surface with a leather cleaning brush. This removes stubborn grime and will not harm the leather. Use a clean, damp sponge to rise the leather. Towel dry with a clean terry cloth towel. In addition to regular cleaning, leather requires replacement of natural oils. (The smell of leather comes from oils evaporating out of the hide.) If these oils are not replaced, the leather will dry out, deteriorate and crack. Once every month or two, use a leather conditioner to restore these natural oils and keep the leather soft and supple. Leather conditioners with rich combinations of natural oils like Pinnacle Leather Conditioner are especially beneficial on neglected, abused or aged leathers that have developed "character lines".To properly condition leather: Apply conditioner to a damp applicator pad and wipe all leather surfaces in the vehicle. Allow 15 to 20 minutes for the oils to penetrate and give a final wipe down with a clean towel. Don't be alarmed if there is conditioner on the wipe towel. The leather will only absorb as much conditioner as it needs.If you own a convertible with a leather interior, you should consider additional sunscreen protection. Leather conditioners typically do not offer any UV screening. The best solution is to alternate between a leather conditioner and 303 Protectant. One month I'll use a conditioner to keep the leather healthy and supple. the following month, I'll mist and wipe the leather with 303 protectant to add UV protection.Coated or "Corinthian" leather.Some leather being used in domestic automobiles has a top veneer of vinyl. This should be considered a vinyl interior and treated with a vinyl dressing. Do not use a leather conditioner on vinyl topped leather. The conditioning oils can not penetrate the vinyl coating to reach the leather. If you're not sure if your car's leather is vinyl coated, check with your car dealer or the manufacturer.
Posted: Mon Oct 22, 2007 5:56 am
by MRCN RCE
time to bring this one back from the dead.whelan, what's the best thing i can get for my leather seats besides what this guy talked about?? i'd rather use meg's, since i've never had a problem with any of their products in the past
Re: (MRCN RCE)
Posted: Mon Nov 05, 2007 11:17 pm
by Whelan
That's an easy one. Although these won't leave that shiny shiny look, it will make your leather look and feel great again.The first one This gets the leather clean and soft, really does a fantastic job. It's good if your leather is already fairly clean and just needs a freshen up.The second is a two stepFor more serious jobs, you have the two step, one is solely a cleaner to get the leather free and clear from dark spots and contaminents. The second step conditions the leather with aloe to soften it, and replenish the oils. For inbetween jobs you can use the wipes as well.This leaves a bit more shine but also cleans fairly well in between.
Posted: Sun Nov 18, 2007 4:45 pm
by MRCN RCE
thanks whelan. i'm gonna get the 2 step n use that, since i haven't done any leather treatment on the interior since i bought it last year i usually just wipe em down with wet MF towels.
