clicking noise?
Posted: Tue Aug 24, 2004 10:45 am
by blankskeme
I have a 03 vibe and now I also have this clicking noise just behind the glove box. I have taken the glove box off and can see that the noise is coming from right above the air filter where a a panel goes back and forth when you press the recirculate (sp?) button just under the AC button. The odd thing is that it only makes the noise when that panel is closed (when I DON'T have the recircualte button press) . I was wondering if any of you have had this happen and any thoughts on what I can deo to fix it aside from just leaving the recirculate button on.Thanks in advance!!!!
clicking noise?
Posted: Wed Aug 25, 2004 3:55 am
by blankskeme
I have a 03 vibe and now I also have this clicking noise just behind the glove box.I have taken the glove box off and can see that the noise is coming from right above the air filter where a panel goes back and forth when you press the recirculate (sp?) button just under the AC button.The odd thing is that it only makes the noise when that panel is closed (when I DON'T have the recircualte button press) .I was wondering if any of you have had this happen and any thoughts on what I can deo to fix it aside from just leaving the recirculate button on.Thanks in advance!!!!
Re: clicking noise? (blankskeme)
Posted: Tue Aug 31, 2004 11:50 am
I haven't had a chance to check mine out yet. The recirc probably closes a door to cut off outside air, does it sound like it's a flap or a door rattling? Does fan speed affect the sound?
Re: clicking noise? (joatmon)
Posted: Fri Sep 17, 2004 1:36 am
by blankskeme
joatmon,thanks for the reply...it is still making the clicking noise and I am almost positive it isnt the fan or anything caught inside there. in my none professional opinion I think the motor (or whatever closes the panel) doesn't know when to stop turning. It is like it is trying to close it and keeps turning even though it is already closed and causing the clicking sound.Didnt know if this sounded famliar to anyone on here...any solutions would be great!thanks!
Posted: Sat Sep 18, 2004 8:37 am
by ColonelPanic
Quote »in my none professional opinion I think the motor (or whatever closes the panel) doesn't know when to stop turning. It is like it is trying to close it and keeps turning even though it is already closed and causing the clicking sound.I think you're on the right track there. There was at least one thread that I know of with a problem that sounds similar to yours... I'd bet something with the recirculate motor or various other components have become stripped and aren't able to open/close the door properly.
http://forums.genvibe.com/zerothread?id=4456
Re: clicking noise?
Posted: Sat Sep 18, 2004 8:49 am
good find CP!blankskeme, are you still under warranty?
Posted: Sun Sep 19, 2004 11:01 pm
by blankskeme
that thread is exactly what my car is doing...thanks CPI did try to pull the plug on the little motor but could get my hand in there for a good grip. no I am not under warranty which sucks so looks like I am off to the dealership. thanks again!!!
Posted: Mon Sep 20, 2004 9:23 am
by ColonelPanic
Good luck to you! Let us know what had to be done... Hopefully by knowing the source of the problem, the guys at the shop can fix it quicker.
Re: clicking noise? (ColonelPanic)
Posted: Tue Sep 21, 2004 8:41 am
by blankskeme
thanks cp... I will post the outcome after I get it fixed....
Posted: Thu Apr 28, 2005 7:39 am
by dmfort
Mine too. although in both open and closed directions.Did you ever get yours fixed?
