quick oil filter and oil ?
Posted: Sat Aug 21, 2004 12:15 am
by mrgrn
I have a 2003 GT and read through some searched topics. I thought i found that the FRAM PH3614 would be a good choice and wanted to be sure before dropping the oil? I also would like to know if i should take off the filter first when draining? if so will oil come out of there? I lastly would like to know at what milage are people changing the oil and filters? i am using mobil 1 5-30 semi.any help would just be awesomeTIA
Re: quick oil filter and oil ? (mrgrn)
Posted: Sat Aug 21, 2004 12:22 am
by Sub-Vibe-R
Quote, originally posted by mrgrn »I have a 2003 GT and read through some searched topics. I thought i found that the FRAM PH3614 would be a good choice and wanted to be sure before dropping the oil? Fram filter are okQuote, originally posted by mrgrn » I also would like to know if i should take off the filter first when draining? I always drain the oil pan first, then I remove the oil filter.
Re: quick oil filter and oil ? (Sub-Vibe-R)
Posted: Sat Aug 21, 2004 12:49 am
by nismo
think that's what you're supposed to do anyways. If I'm not mistaken.Inder Singh
Posted: Sat Aug 21, 2004 1:31 am
by Mr. Poopypants
I use Mobil1 oil and a Purolator PureONE filter. Seems to be working great for me.Yeah, drain first.
Re: quick oil filter and oil ? (Mr. Poopypants)
Posted: Sat Aug 21, 2004 1:37 am
by nismo
Quote, originally posted by Mr. Poopypants »Purolator PureONE filter.Where did you get that filter from. Never heard of it.Inder Singh
Re: quick oil filter and oil ? (TRD4reel)
Posted: Sat Aug 21, 2004 2:28 am
I've been using the Pure one filter, some poeple don't like Fram, they got some bad press for a while. There's a auto parts store chain around me called Advance Auto, that's where I've bought mine. last time I checked there was no Purolator PureONE oil filter for the GT.there's a longer thread about Vibe oil filters at
http://forums.genvibe.com/zerothread?id=4451I drain the oil from the pan before removing the filter. Always done it that way. Probably doesn't matter, but since I always get a little oil run down the side of the filter, I figure maybe I'd get a lot more if I loosened the filter before draining the pan. it's a lot easier to control the oil from the pan drain than what leaks out when you remove the filter. On some car's I've had, the oil filter isn't vertical, and you make a big mess when you pull the filter. On some the oil would leak down the side of the block. On the base vibe engine, the filter hangs down, and is a little away from the engine, so any that leaks fall clear of the engine, and are easy enough to catch.I'm still using Castrol GTX 5W30, and have been changing it about every 5K miles or so.There are a bunch of threads about vibe oil changes, like
http://forums.genvibe.com/zerothread?id=876
Posted: Sat Aug 21, 2004 2:36 am
I use Mobil1 and a toyota filter (or ACDelco when I can't get the toyota one)
Re: quick oil filter and oil ? (joatmon)
Posted: Sat Aug 21, 2004 2:38 am
by nismo
I've heard of that place before. How much does that filter run ya?Inder Singh
Posted: Sat Aug 21, 2004 2:39 am
still about five bucks ( see thread 4451 )
Posted: Sat Aug 21, 2004 2:41 am
by nismo
ahh. Cooo. Thanks for the info. Look into that.Inder Singh
Posted: Sat Aug 21, 2004 8:25 am
by Mr. Poopypants
Quote, originally posted by TRD4reel »Where did you get that filter from. Never heard of it.Inder SinghAdvance auto parts.
Posted: Mon Aug 23, 2004 1:39 am
by ToolGuy
Quote, originally posted by mrgrn »I have a 2003 GT and read through some searched topics. I thought i found that the FRAM PH3614 would be a good choice and wanted to be sure before dropping the oil? I also would like to know if i should take off the filter first when draining? if so will oil come out of there? I lastly would like to know at what milage are people changing the oil and filters? i am using mobil 1 5-30 semi.any help would just be awesomeTIADo not have a GT but if I did I would use AC Delco like in my base Vibe. With AC you cannot go wrong, tests have proved AC to be a great filter. Search the net under oil filter tests some guy bought just about every filter he could find, took them apart and analyzed them by their filter medium and bypass valves. Drain first then I punch a hole in the bottom of the filter to drain it more before removal. Since it is vertical, it usually stays full until you spin it loose and dumps oil on your hand. I use a brand name oil and change it every 3000 miles.
Posted: Mon Aug 23, 2004 9:24 am
by mrgrn
thanks to all. i used the mobil 5-30, and them fram 3614($3) and it went like a charm.
