Ground Control Street Use Adjustable Spring Kits
Posted: Fri Oct 25, 2002 12:04 am
Vibe Part # 8070.01 Height adjustment 1.5 to 2.8 Price $419 Matrix Part # 8070.01Everything is the same as the Vibe. This system allows you the option to customize the ride height of your vehicle. Unlike other spring kits that require removal of the strut assembly, the unique design of the Ground Control kit allows for quick, easy adjustment. Simply lift the corner(s) to be adjusted and spin the adjuster up or down to raise or lower the vehicle. Ground Control spring kits are designed to be used with either stock or aftermarket shocks. Springs: All our ride height adjustable kits feature Eibach Springs. these high quality springs offer a lifetime warranty against any defects. Adjusters: All adjusters consist of a threaded sleeve and adjustable spring seat and are made using 6061 aluminum, anodized for greater durability and appearance. All other adapter hardware is machined from the same high strength 6061 T-6 aluminum. Ground Control
