Rear Window Wiper Insert
Posted: Mon Aug 16, 2004 3:04 am
by redbeagle
Does anyone know the correct part number for the Toyota Rubber Wiper Insert for the rear window. The Matrix and Vibe inserts are the same, I have confirmed that. The local Toyota Dealer supplied me Part No 85214-12310 on my invoice, this is the incorrect part number. The rubber insert is too long; they told me to cut it down ! Ya right !Wrong, I would rather buy the correct part. Does anyone know the correct part number ? Thank you for your assistance. Redbeagle
Re: Rear Window Wiper Insert (redbeagle)
Posted: Mon Aug 16, 2004 3:15 am
by ragingfish
Here's a how to on replacing the blade.The part number is on the top:
http://forums.genvibe.com/zerothread?id=7733
Re: Rear Window Wiper Insert (Salsa!)
Posted: Mon Aug 16, 2004 3:27 am
by ragingfish
Quote, originally posted by Salsa! »Hey Mike, I might be wrong, but I heard from a friend Matrix owner that you can get the entire arm with wiper blade from Toyota....Even if the install/replacement is easy, you get can an even easier (a bit more expensive) replacement plastic arm.Anyone else heard of this?!Correct.85242-12090 is the part number for the entire assembly, including the insert.85214-12310 is the insert only.
Posted: Mon Aug 16, 2004 3:32 am
by ragingfish
You can get it from brandsport.com for about $12 shipped (+$4.50 handling for orders under $25.). Shipping is more outside the lower 48.
http://www.brandsport.com/toy-85242-12090.html
Re: Rear Window Wiper Insert (ragingfish)
Posted: Mon Aug 16, 2004 4:09 am
by redbeagle
Ragingfish,It looks to me like the part number you supplied is the same as the part number on my invoice, 85214-12310, cost $2.35I would bet someone put the incorrect part in the bin, therefore I am being handed the incorrect part. I will attempt to get the correct part again. Persistence will pay off !All of the wiper inserts are a piece of cake to replace.Thank you for your assistance. Regards, Redbeagle
Posted: Tue Aug 17, 2004 10:35 pm
by ToolGuy
Always clean all my wipers with alcohol or wiper solution and a rag. Removes all the dirt/grime and wipers do not skip. Wipers last for years doing that. Obviously if they are torn then they need to be replaced.Clean your new insert and it will last a long time...
Posted: Wed Aug 18, 2004 12:03 am
by kostby
Don't forget to RainX the rear glass.
Re: (kostby)
Posted: Wed Aug 18, 2004 12:21 am
by ragingfish
Quote, originally posted by kostby »Don't forget to RainX the rear glass. Doesn't do any good.Remember -- RainX relies on wind to work. Notice when you're at a stop, rain puddles on your glass like it normally would. Not until you are moving does it actually start to do it's job...
Re: Rear Window Wiper Insert (MiVibe-ToolGuy)
Posted: Wed Aug 18, 2004 1:36 am
by redbeagle
ToolGuy, I contacted the local Toyota Dealer yesterday. Just as I said someone had put some incorrect rubber inserts in the bin and I was handed the incorrect one. They set one aside for me to pickup today, it should fit fine (they measured the length for me).I will try cleaning the inserts in the future with alcohol to keep them in clean condition.Regards, Redbeagle
Posted: Thu Sep 08, 2005 2:03 am
by Flip-Side
Quote, originally posted by ragingfish »You can get it from brandsport.com for about $12 shipped (+$4.50 handling for orders under $25.). Shipping is more outside the lower 48.
http://www.brandsport.com/toy-85242-12090.htmlThanks a bunch Ragingfish. Mine got bent, and I have to replace the whole blade. The pontiac dealer wanted $38 for it, so this will help me out.
Re: Rear Window Wiper Insert (Flip-Side)
Posted: Thu Sep 08, 2005 5:46 am
by Altus
Yeah when I went to replace the blade (the blade itself, not just the edge insert, and not the whole arm, just the blade like normal) GM wanted $27+tax CDN for it - yeah right. So I went to Toyota - same part $14 after tax. Canadian of course. Just ask for the rear wiper for a Matrix.
Posted: Wed Oct 19, 2005 11:18 am
by herm1959
there is not one available by GM as I just got one for mine and the only way I could get it is buying the whole blade
