Change 2x 10" Sony X-Plod to a 12" JL
Posted: Wed Oct 23, 2002 11:43 pm
by Sub-Vibe-R
I figure out changing my subwoofer.Actually, I have 2 10" sony X-Plod and I want to change them for 1 12" JL audio. I want the 12w3v2. It will give me much punch then my Sony's and will take less space in my trunk.I'm also considering the 10w3v2.What could be the best choice: stay with my Sony's, buy the 12" JL and go with the 10" JL?I have a power amp JBL 180.2 (180w x2 @ 2 ohm or 360w x1 @ 4 ohm bridged) to drive this. My head unint is a Pionner DEH-P8400I want your opinion on this
Re: Change 2x 10" Sony X-Plod to a 12" JL (Sub-Vibe-R (Ben))
Posted: Sun Oct 27, 2002 9:16 pm
by yank dini
Check the RMS power for both subs. If your amp falls with the higher range of the RMS for the subs then that would be a good match and you will maximize the potential power of those indivdual subs that you want to use.ex. MTX 12inch sub with 50min-250max RMS AMP is 180 x2 @2 ohms since the amp kicks out 180 x2 you would want some subs that carry at least 50-watts of power RMS not to exceed 200 to 250 that way the subs will "knock" instead of "tapping"
Re: Change 2x 10" Sony X-Plod to a 12" JL (yank dini)
Posted: Sun Oct 27, 2002 10:36 pm
by Sub-Vibe-R
My X-POLD drive max 400w peak JL 10" and 12" can take 350w RMS easy and up to 500w RMS at the read line.My amp dirve 360w RMS @ 2 ohms bridged.I think I will have the optimal setting sub/amp with the JL but I'm not sure if should go with a 10 or a 12" speaker
Posted: Sun Oct 27, 2002 10:49 pm
by yank dini
10's have tighter bass.12's have more deeper low end richer bassif you want to be heard blocks away you're gonna need 12's
Posted: Sun Oct 27, 2002 11:24 pm
by Sub-Vibe-R
I think I'll go for the 12"I will keep you updated when the sub will be installed.It should be in few weeks. I'm still waiting for my Vibe. I should have it in few days.
JL Stealthboxes
Posted: Fri Nov 01, 2002 6:06 am
by Celos
Hey, just as an FYI, I sent an email to JL Audio recently asking if they were considering making a "Stealthbox" for the Vibe/Matrix. For those who don't know what a Stealthbox is, it's a subwoofer in an enclosure that's designed to fit in your car and look like it's factory equipment. They don't take up a lot of space and they match the finish of your car. Info at http://www.jlaudio.com/stealthbox/index.html.They replied and said they're strongly considering it, so if anybody wants one made available, go to the JL site and send 'em feedback. I like 'em because you get a tuned enclosure and it's, well, stealthy. Easy, too.
