Psi, horsepower, and transmission
Posted: Tue Aug 03, 2004 3:48 am
by Smokin' Rubber
So I sorta explained before the plans for my car but I was just thinking what kind of psi I would be able to run the car at so its just below the 280 max hp that the tranny can take. Also anyone know if there is a way to beef up the transmission or if there is a stronger 6 speed I could put in our car like a Honda S2000 6 speed or an RSX-S 6 speed? Unfortunately I'm not going to be able to turbo it until next year (waiting for the warranty to run out), which I suppose is good so I can accumulate all the parts I want and just have them all installed at once. Crucial parts (excluding the transmission) are going to be about $6500 assuming the turbo kit from stafford is $3,500 (when they actually finish it).On a side note... I wonder which section this will get bumped to since it applies to both the FI section and the engine/transmission section
Re: Psi, horsepower, and transmission (Smokin' Rubber)
Posted: Tue Aug 03, 2004 4:44 am
by Psychobroker
Quote, originally posted by Smokin' Rubber »So I sorta explained before the plans for my car but I was just thinking what kind of psi I would be able to run the car at so its just below the 280 max hp that the tranny can take. Also anyone know if there is a way to beef up the transmission or if there is a stronger 6 speed I could put in our car like a Honda S2000 6 speed or an RSX-S 6 speed? Unfortunately I'm not going to be able to turbo it until next year (waiting for the warranty to run out), which I suppose is good so I can accumulate all the parts I want and just have them all installed at once. Crucial parts (excluding the transmission) are going to be about $6500 assuming the turbo kit from stafford is $3,500 (when they actually finish it).On a side note... I wonder which section this will get bumped to since it applies to both the FI section and the engine/transmission sectionUm, for that total price, you might want to find a used Subi WRX..
Re: Psi, horsepower, and transmission (Psychobroker)
Posted: Tue Aug 03, 2004 4:50 am
by Smokin' Rubber
Quote, originally posted by Psychobroker »Um, for that total price, you might want to find a used Subi WRX..Lol its not that much, the $3,500 is PART of the $6,500, can't get a used WRX for that much unless its like 10 years old. Not to mention that fact that the Vibe is more versatile and is more unique
Posted: Tue Aug 03, 2004 6:09 am
by satur9
i thought i answered these questions already...however if you want more detailed info check out
http://www.newcelica.org thats where the turbo 2zz's are so thats were youll get the most feedback.
Re: Psi, horsepower, and transmission (satur9)
Posted: Tue Aug 03, 2004 6:35 am
by Smokin' Rubber
yeah I think you said that they are trying to make a eurospec transmission but I'm saying will any other trannies fit or can I strengthen the current one? It didn't look like the celica site had anything but I'll check again just in case
Posted: Tue Aug 03, 2004 1:15 pm
by Faultline
I spoke to Stafford a few days ago, and they put the 6spd celica gt-s tranny in to the 5spd celica gt. He told me it bolted right up. It remains to be seen if it is any stronger though...time will tell...He said it was fun to drive though,..how 4th in the 6spd seemed like somewhere between 3rd and 4th in the 5spd...and how under boost it felt real good!Some say the 6spd maybe weaker?????My advise is to take one thing at a time...break the tranny 1st, then worry about fixing it !!!
Re: Psi, horsepower, and transmission (Faultline)
Posted: Tue Aug 03, 2004 2:17 pm
by Smokin' Rubber
But I have the 6 speed already lol I wonder what the weak part of the tranny is. Maybe if I knew I could figure out a way to strengthen it.
Posted: Tue Aug 03, 2004 3:41 pm
by Psychobroker
Quote, originally posted by Smokin' Rubber »Lol its not that much, the $3,500 is PART of the $6,500, can't get a used WRX for that much unless its like 10 years old. Not to mention that fact that the Vibe is more versatile and is more unique Ahh, ok
Posted: Tue Aug 03, 2004 9:02 pm
by goodvibe
The final drive shears. You may be able to push it a bit with RP maxgear fluid in the tranny. It has the highest load ratings I've ever seen and is also low friction. I didn't like it in the winter and switched to Torco RTF but I don't know if Torco would hold up as well in a turbo.
Re: Psi, horsepower, and transmission (goodvibe)
Posted: Tue Aug 03, 2004 9:23 pm
by Smokin' Rubber
ok so the teeth on the gears themselves are the weak link. I know this sounds kind of stupid but I wonder if I could get the gears forged and whether or not that would prevent the shearing
Posted: Tue Aug 03, 2004 10:22 pm
by goodvibe
You could cryo treat the stock ones or buy c-one.
Posted: Tue Aug 03, 2004 11:14 pm
by Fialchar
Some companies make aftermarket transmissions, I saw a 6 speed one in a recent import magazine I got. I'll try to fnid it for you so we can find out if it'll fit the Vibe.
Re: Psi, horsepower, and transmission (Fialchar)
Posted: Wed Aug 04, 2004 1:05 am
by ToolGuy
The S2000 and RSX are RWD cars and their trans will not work unless heavy modding is done. I would look at other FWD's like possibly the PT Cruiser GT Turbo or Neon SRT manual trans made by Getrag. Those cars trans already can handle 215 HP & 230 Ft. of Torque from the factory and through Mopar Parts, there are three turbo kits to increase power. No changes to the trans are necessary with any of the Mopar upgrade kits. Or an aftermarket trans... $6,500 for all is too much though...
Re: Psi, horsepower, and transmission (MiVibe-ToolGuy)
Posted: Wed Aug 04, 2004 6:14 am
by satur9
c2 gas i believe is working on stronger(3x)GEARS for the eurospec tranny.they should fit your tranny just with different ratios.theres tons of post over there about it.you may have to search though.c-one also makes a set for like 3000 dollars but thier gears ratios are more for road racing.
Posted: Wed Aug 04, 2004 7:34 am
by Smokin' Rubber
Hmmm I wonder which way would be the best to go.... so I have about 3 choices then: C2 eurospec, C-One racing geared, or try to get the stock ones cryo treated
Posted: Wed Aug 04, 2004 12:48 pm
by nismo
Okay, Why don't u do this. See how much u can get a Scion tC tranny. That is a 6-speed. Since that tranny is made to handle more torque. It should be able to handle higher boost = ing more horses. More horses, the happier we are.Inder Singh
Re: Psi, horsepower, and transmission (TRD4reel)
Posted: Wed Aug 04, 2004 7:26 pm
by Smokin' Rubber
Yeah the problem is does it fit in the Vibe? Our transmission is actually fairly compact (hence toyota's bragging rights to having the lightest engine and tranny combo in its class)
Posted: Thu Aug 05, 2004 1:28 am
by nismo
If u're plannin on keepin ur Vibe, then there's always room to modify the underbody or even the cabin. That is, if u have the $ to do that. Just sayin.Inder Singh
Posted: Thu Aug 05, 2004 10:04 am
by Smokin' Rubber
Hehe very true, we'll see I still got another year to save up money since I'm not going to do any severe engine mods until the 3 year warranty is up (the january after this coming one).
