How to choose shock absorbers
Posted: Sun Oct 20, 2002 11:19 pm
SHOCK ABSORBER TECH INFO ARE SHOCK ABSORBERS REALLY THAT IMPORTANT? Shock absorbers are a critical component for eliminating unwanted and excess motion in the body and suspension. Without shock absorbers, cars and trucks would bounce down the road in an uncontrollable fashion. Without shocks, tires would lack adhesion and braking and cornering would be somewhere between dangerous and impossible. Shock absorbers play a critical role in vehicle stability and safety. HOW DO SHOCK ABSORBERS DO THEIR JOB? By forcing a piston through oil, shocks develop the hydraulic friction necessary to resist unwanted and excess suspension motion. Shocks work in two directions called compression (the closing motion) and rebound (the opening motion). Shock absorbers are supposed to minimizeunwanted and uncomfortable body motions such as pitch and side to side rocking. They must also keep the tire in maximum contact with the road surface. HOW CAN I TELL IF MY SHOCKS NEED REPLACEMENT? The best way to determine whether you shocks are working properly is to drive your car or truck over familiar roads with various surfaces and bumps. And while a leaking shock is an obvious candidate for replacement, many shocks wear out without losing any oil. If your vehicle is exhibiting any of the following characteristics, then you may need new shock absorbers. The more characteristics you experience the more likely it is that your shocks should be replaced. IS MILEAGE A GOOD INDICATOR OF SHOCK WEAR? Mileage alone is a poor indicator of shock performance. Some shocks are still working well after 30,000 to 40,000 miles. Others need replacement in as little as 4,000 miles. In fact some shocks are so poor that they do not work properly when brand new! Another test was the old "bumper bounce test". This test is a worst case evaluation. Shocks are usually performing poorly well before this test shows anything. If your vehicle has very stiff springs, like some trucks, the bumper test is almost impossible to perform. HOW DO SHOCK BRANDS DIFFER? Virtually everyone who manufactures shock absorbers claims to use the best materials and have the best design. However not all of these "bests" are equal. There are very real differences in the materials, tolerances, and actual internal designs of different manufacturers. Keep in mind that quality has an effect on how long the shock will last and how even or consistent the performance will be. Design has a major effect on how the shock actually works. Good quality and sophisticated designs tend to be more expensive to manufacture than poor quality outdated designs. Controlling both excess body motion and the tires and wheels properly requires sophisticated oil flow management. Inexpensive shocks simply cannot do both jobs correctly. WHAT ARE GAS SHOCKS? The oil used in shock absorbers has some air in solution. The rapid movement of the shock piston causes what is called cavitation. This results when the air in the oil comes out of solution to form foam. Foamed oil will not provide proper resistance. This affects shock performance. By pressurizing the oil, engineers can eliminate the negative effects of cavitation. The result is better more consistent control and superior ride quality. There are two types of gas pressurized shock absorbers. Monotube-high pressure units and twin-tube low-pressure shocks. There are also a number of designs within these two categories. It is important to realize that simply adding gas pressure to a poor quality shock will not make it into a high quality unit. DOES A WARRANTY MEAN ITS A GOOD SHOCK? Warranties are like ears, virtually everyone has them. They are marketing tools, and they offer no indication of the quality or design of a shock absorber. In fact some manufacturers simply raise the price of their inexpensive shocks to cover warranty costs. A warranty may get you a free replacement, but warranties rarely cover labor costs. It is better to invest in the type of quality that rarely requires replacement.
