CAI installed...first start up running at 2800 RPM
Posted: Tue Jul 20, 2004 6:39 am
by silvervibeGT
is this normal?? or did I miss someting, please help!
Re: CAI installed...first start up running at 2800 RPM (silvervibeGT)
Posted: Tue Jul 20, 2004 6:41 am
by Psychobroker
I don't understand your question/problem...do you mean it won't rev PAST 2800? If so, sounds like your MAF might be toast.
Posted: Tue Jul 20, 2004 6:42 am
by VibeChick
What do you mean? That it will only run up to 2800 RPM?If so, then your MAF sensor is toast. You'll have to get it replaced
Re: CAI installed...first start up running at 2800 RPM (Psychobroker)
Posted: Tue Jul 20, 2004 6:43 am
by VibeChick
Jinx!! lol
Re: CAI installed...first start up running at 2800 RPM (VibeChick)
Posted: Tue Jul 20, 2004 6:52 am
by Psychobroker
Quote, originally posted by VibeChick »Jinx!! lolOMGs!
Posted: Tue Jul 20, 2004 7:12 am
by silvervibeGT
no no no it's ideling at 2800
Posted: Tue Jul 20, 2004 9:32 am
by Stang2Vibe
I think it is probably because there was a change for the Vibe GT '04 model in the air intake system. I'm not absolutely positive, but I think that Injen only offers a CAI for the '03 Vibe GT at this time. The MAF sensor is probably fine and doing it's job correctly, but the computer is misunderstanding the input from the sensor and turning up the idle due to the change in readings now caused by the installation of the CAI. I'm no certified mechanic, but that would be my guess.The '04 has some kind of smog pump that the '03 didn't have, so I'd bet that this difference between the model years is what is screwing things up.
Posted: Tue Jul 20, 2004 12:03 pm
by Evanshall
hmm, wish i knew, my moms 1970 mustang with a aluminum big block used to idle at 5000 and it ran great, but thats a different type of car all together hehe, sorry just had to brag about my mommy
Re: (Evanshall)
Posted: Tue Jul 20, 2004 12:29 pm
by NovaResource2
Quote, originally posted by Evanshall »hmm, wish i knew, my moms 1970 mustang with a aluminum big block used to idle at 5000 and it ran great, but thats a different type of car all together hehe, sorry just had to brag about my mommy An aluminum big block 1970 Mustang that idled at 5000 rpm?! Let me know when you come back to reality.
Re: (NovaResource2)
Posted: Tue Jul 20, 2004 12:40 pm
by FusionVGT
Quote, originally posted by NovaResource2 »An aluminum big block 1970 Mustang that idled at 5000 rpm?! Let me know when you come back to reality.I can only smile at this one...
Re: (FusionVGT)
Posted: Tue Jul 20, 2004 7:52 pm
by Mavrik
You have the vac lines attached properly, you didn't accidently move the throttle cable? Your filter isn't jammed up so far on the tube its not allowing air in?
Posted: Tue Jul 20, 2004 11:21 pm
by Evanshall
thats what she told me, if she wants to lie thats her, im just saying what she told me, uhg, yah it is qeut unbeleiveable isnt it ive been back to reality, i just gotta wiat for my mom to get back to reality
Re: (Evanshall)
Posted: Wed Jul 21, 2004 12:38 am
by goodvibe
ive been back to reality [/QUOTE]But where are you now. I spew, therefore I am. Warning, warning, buffers have failed.
Re: (Mavrik)
Posted: Wed Jul 21, 2004 3:15 am
by Psychobroker
Quote, originally posted by Mavrik »You have the vac lines attached properly, you didn't accidently move the throttle cable? Your filter isn't jammed up so far on the tube its not allowing air in?If the airflow was blocked, I'd think the engine would sputter/die ?
Re: (Evanshall)
Posted: Wed Jul 21, 2004 7:29 am
by savedbyzero
Quote, originally posted by Evanshall »hmm, wish i knew, my moms 1970 mustang with a aluminum big block used to idle at 5000 and it ran great, but thats a different type of car all together hehe, sorry just had to brag about my mommy maybe once...
Re: (Evanshall)
Posted: Wed Jul 21, 2004 9:31 am
by NovaResource2
Quote, originally posted by Evanshall »thats what she told me, if she wants to lie thats her, im just saying what she told me, uhg, yah it is qeut unbeleiveable isnt itTo quote an old saying: "The older I get, the better I was."Maybe she really meant 500 or 1000 rpm.
Re: (Psychobroker)
Posted: Wed Jul 21, 2004 11:39 am
by Mavrik
Quote, originally posted by Psychobroker »If the airflow was blocked, I'd think the engine would sputter/die ?Yes it would actually but hey, I'm just tossing out ideas. My prob with my CAI install is that afterwards my car didn't want to rev higher then 2800rpms lol... damn MAF
Re: (Mavrik)
Posted: Wed Jul 21, 2004 3:21 pm
by Psychobroker
Quote, originally posted by Mavrik »Yes it would actually but hey, I'm just tossing out ideas. My prob with my CAI install is that afterwards my car didn't want to rev higher then 2800rpms lol... damn MAF yeah, well no one told you to go and pour a quart of oil on it, now did they?
Re: CAI installed...first start up running at 2800 RPM (Stang2Vibe)
Posted: Wed Jul 21, 2004 3:31 pm
by AKLGT
brandon, injen is the only one that makes a CAI for the 04+ 2zz engines. i believe it goes around that smog pump. swirv has one and now silvervibeGT. i've not done an install on one yet, so i can't say what that fog pump looks like.
Re: (Psychobroker)
Posted: Wed Jul 21, 2004 7:54 pm
by Mavrik
Quote, originally posted by Psychobroker »yeah, well no one told you to go and pour a quart of oil on it, now did they? Actually I didn't but you could have helped with the install but you tried to fly air canada
Re: (Mavrik)
Posted: Thu Jul 22, 2004 3:53 am
by silvervibeGT
does anyone have a pic of CAI installed on an 04 GT? I want to look at the hoses and their placement
Re: CAI installed...first start up running at 2800 RPM (trdvibe)
Posted: Thu Jul 22, 2004 4:06 am
by Stang2Vibe
Quote, originally posted by trdvibe »brandon, injen is the only one that makes a CAI for the 04+ 2zz engines. i believe it goes around that smog pump.Hmm, well then I will default to the answer that others on the board have offered. Possibly it is incorrectly connected vacuum hoses? Also others have sensibly noted that immediately after installing a CAI on these cars it is necessary to just start the car up and do nothing but let it idle for about 10 min so that the computer can readjust to the new input from the sensors.
Re: (Mavrik)
Posted: Wed Aug 04, 2004 11:00 am
by Jerm
Try to disconect the battery for about 20 minutes or so. the computer might need to reset
