Aem Pulleys
Posted: Mon Jul 19, 2004 10:20 am
by rcasciola
has anyone installed the aem pulleys on their vibe/trix? and if so had any poblems...
Posted: Mon Jul 19, 2004 10:40 am
by Evanshall
theres been problems with cosmo pulleys i think, AEM though i havnt heard good or bad about, there supposed to be good, but as well there was a problem with atleast the other pulleys that caused oil pumps to shatter(not good at all), i would do more research around myself read reviews for even other cars as every little but helps
Re: (Evanshall)
Posted: Mon Jul 19, 2004 10:52 am
by goodvibe
AEM don't supply a crank pulley so it ahouldn't be dangerous. Not much gain though.
Re: Aem Pulleys (rcasciola)
Posted: Mon Jul 19, 2004 10:55 am
by wicked1981
Don't get pulleys unless you can pay for a new engine.
http://forums.genvibe.com/zerothread?id ... ad?id=8512
Re: Aem Pulleys (wicked1981)
Posted: Mon Jul 19, 2004 1:14 pm
by goodvibe
Only the crank pulley can cause the imbalance/vibration problem. Accessory pulleys aren't an issue. AEM doesn't supply the crank pulley. Check your second (earlier) link. I brought it up. Got it from the Celica forums.
Posted: Mon Jul 19, 2004 11:55 pm
by Flip-Side
I don't think the AEM pulleys are worth it. Only tiny amounts of power can be gained from changing the alternator pulley. They are just for looks in my opinion.I was looking at underdrive pulleys, but decided against possibly destroying my vibe. Thanks to some people here for educating me.
Re: Aem Pulleys
Posted: Tue Jul 20, 2004 10:05 am
by Stang2Vibe
The problem with the aftermarket pulleys is that they lack a harmonic balancer on the crank pulley. That is what was causing the oil pump to shatter which in turn caused the engine to fail. I would also imagine that a poorly balanced accessory pulley can cause premature wear on the bearings in that accessory, though.
Re: Aem Pulleys (Stang2Vibe)
Posted: Tue Jul 20, 2004 9:41 pm
by goodvibe
The accessory pulleys don't have balancers and are lighter than stock so that any effect of machining errors would be reduced over stock. Again, I don't think they are worth the effort unless you like the pretty colors. The crank pulley also effects the crank bearings but the oil pump is the first to go. It may be related as the pump is driven off the crank.
