low beams to low?
Posted: Sat Jul 17, 2004 12:41 pm
by jgvibe
Does anyone else feel there lights are to low when on low beam? I swear i can bearly see 5 car lengths at night. I thought low beams were supposed to light up about 300 feet ahead of you or so.
Re: low beams to low? (jgvibe)
Posted: Sat Jul 17, 2004 12:46 pm
by scherry2
only because I lowered my vibe.
Posted: Sat Jul 17, 2004 8:50 pm
by MadBill
Yes, I found they were too low, so I cranked them up just a little. The cutoff at the top of the beam is so sharp that it's easy to see when following another car if you're starting to shine in their mirror. Also, there's quite a wide split between low and high, so if you go too high, not only will you get flashed by approaching traffic, but high beams will only be good for blinding owls...
Posted: Sun Jul 18, 2004 12:25 am
Ask your dealer to check the aim on them.
Re: low beams to low? (ragingfish)
Posted: Sun Jul 18, 2004 1:22 am
by Mavrik
Clean the lens to and see if that makes a difference because that can also redirect the light downward. I've seen that. But the alignment of the assembly might need a bit of tweeking as well.
Posted: Sun Jul 18, 2004 4:01 am
by Raven
Use the search fuction, there are instructions for adjusting them etc.
