Intake help
Posted: Thu Jul 15, 2004 9:28 pm
by silvervibeGT
I have just recieved my Injen CAI for my 04 GT, I was told that if I made a post here you guys could help me out. I have not attempted to install it as of yet due to the weather on the east coast but I plan on installing it on Wednesday. I was told that the 04's+ GT have a smog pump on them that needs to be delt with. Also any other help or tricks about the install that you could share would be great. Thanks
Re: Intake help (silvervibeGT)
Posted: Fri Jul 16, 2004 12:49 am
by DjDoubleLP
What is it exactly that you want to know about the smog pump??
Re: Intake help (DjDoubleLP)
Posted: Fri Jul 16, 2004 1:02 am
by silvervibeGT
I was told by trdvibe that the 04 GT's have a smog pump that the 03's don't have and that I mite have trouble with that, but I haven't installed it yet so I don't know, they told me to ask you cause you have an 04 matrix and that you could help with anything I mite run inot during the install. Will the pump connect to the intake or what should I do with it, I didn't see anything about it in the instructions so I figured I would ask before I started it. Thanks for the help..
Posted: Fri Jul 16, 2004 1:20 am
by SWiRv
Here's the thread with my CAI experience. If you didn't get my IM, let me know and I'll repost.
http://forums.genvibe.com/zerothread?id=10684
Re: Intake help (SWiRv)
Posted: Fri Jul 16, 2004 1:50 am
by silvervibeGT
hey just IM'd you back, I left my e mail address so you could e mail me that way I can print out what you tell me, that will be easier for me if you don't mind, thanks again
Posted: Fri Jul 16, 2004 2:58 am
by DjDoubleLP
Just make sure that you have the right intake also for the year of the car.......because the 04 Injen did have instructions on the smog pump in it.
Posted: Fri Jul 16, 2004 3:00 am
by silvervibeGT
ok maybe I missed it, but I did order the injen for the 04 XRS, it's a two piece intake. I'll look at it when I go home to make sure.
Posted: Fri Jul 16, 2004 3:18 am
by nismo
Is this the same case on the base model also. B/C i got mine yesterday, plannin on installin it on today.Inder Singh
Re: Intake help (TRD4reel)
Posted: Fri Jul 16, 2004 3:42 am
by wicked1981
Quote, originally posted by TRD4reel »Is this the same case on the base model also. B/C i got mine yesterday, plannin on installin it on today.Inder SinghNo its not same. You should be fine. I have base 04 so if you need help let me know.
Posted: Fri Jul 16, 2004 5:03 am
by AKLGT
Quote, originally posted by TRD4reel »Is this the same case on the base model also. B/C i got mine yesterday, plannin on installin it on today.Inder Singhagain, everyone, please repeat after me:the base engine has NOT changed! ONLY the GT (2zz) engine for 04+if you have a base (1zz) engine this does not affect you in any way. in fact all the changes they've made do not affect you. ONLY, again i repeat, the GT (2zz) engines for 04 or newer.
Re: Intake help (trdvibe)
Posted: Fri Jul 16, 2004 6:55 am
by SWiRv
Guys, don't worry! The smog unit is ONLY on the '04+ GTs. It's a contraption in the lower driver's-side bumper. From the CAI, there are couple hoses that need to be connected to it. Yes, the Injen CAI from the '04 Matrix XRS will fit fine and it is a 2-piece unit.From the sounds of things, it may be a good idea to get a mechanic or mechanically inclined friend to help you out. If anything, there has to be a genvibe member in your area that can help you out.
Posted: Sun Jul 18, 2004 11:59 pm
by silvervibeGT
installed, thanks for the help everyone!
Posted: Mon Jul 19, 2004 12:51 am
by nismo
Hey man,I installed my CAI intake with no problems at all. Jus a lil hard to get up underneath cuz I'm so big. But other than that, it was goin fine. I dunno if the GT has the smog pump and mine didn't. I know there wasn't one from what I could see. So, you should be fine.Inder Singh
Posted: Mon Jul 19, 2004 1:06 am
by AKLGT
hey inder, the SMOG PUMP is on the 04+ GT models. the base doesn't have any of the other vacuum hoses or extra vsv valves either. very very different from the base engine.
Posted: Mon Jul 19, 2004 1:08 am
by AKLGT
Quote, originally posted by silvervibeGT »installed, thanks for the help everyone!good to hear! let us know how it all turns out.
