				What tires fit stock rims?
				Posted: Sun Jul 11, 2004 3:03 pm
				Ok...I searched and searched, but couldn't find anything. I'm trying to figure out what size tires I can buy and still have properly fit on the factory 16" steel wheel. I know sizes both above and below 205/55/16 will fit on the same wheel without problem.I checked tirerack, tires.com, and 1010tires, they don't seem to tell me what tire sizes will fit a specific wheel...Can anyone help me figure out the range of tire sizes I can use on the same wheel, or point me somewhere that will help? Thanks!
				Re: What tires fit stock rims? (ragingfish)
				Posted: Sun Jul 11, 2004 6:00 pm
				by Smokin' Rubber
				how many inches wide are the rims?
				Re: What tires fit stock rims? (Smokin' Rubber)
				Posted: Sun Jul 11, 2004 11:28 pm
				by cohocarl
				Quote, originally posted by Smokin' Rubber »how many inches wide are the rims?I believe the stock steel 16" wheel is 6.5" wide.  I had some aftermarket aluminum wheels that were 16" x 7" and I put some 225/50/16's on them and it looked great.  I think that size may be ok with the 6.5" wide wheel, but may be a little skinny.  The 225/50's have about an inch wider tread, and looked great.  Attached is a pic in which you can kind of see the size.
				Re: What tires fit stock rims? (cohocarl)
				Posted: Sun Jul 11, 2004 11:46 pm
				by Smokin' Rubber
				Judging by the way the sidewalls on the tires are buldging out I wouldn't recommend going above 225 on teh stock 16's then
				Posted: Mon Jul 12, 2004 3:50 am
				by MadBill
				Quote, originally posted by ragingfish »Ok...I searched and searched, but couldn't find anything. I'm trying to figure out what size tires I can buy and still have properly fit on the factory 16" steel wheel. I know sizes both above and below 205/55/16 will fit on the same wheel without problem.I checked tirerack, tires.com, and 1010tires, they don't seem to tell me what tire sizes will fit a specific wheel...Can anyone help me figure out the range of tire sizes I can use on the same wheel, or point me somewhere that will help? Thanks!Mike, the "Specs" page for each brand/model of tire on The Tire Rack's site has this. Along with tire diameter, width, etc. it lists the "design rim width" as well as the minimum and maximum widths for each size tire. There may be minor variations between brands, but if you picka major company and use their data to narrow down your choices you can always double check compatibility for a specific tire when you settle on one.
				Posted: Tue Nov 02, 2004 1:05 pm
				To resurrect an old thread...I'm going to order snow tires tomorrow. I know narrower is better for traction. I want to mount them on my stock 16" x 6.5" rims.What size tire would you recommend for best snow traction on a stock steel wheel that, of course, will not interfere with handling, ABS, or speedometre operation.Thanks y'all!
				Re:  (ragingfish)
				Posted: Wed Nov 03, 2004 9:15 am
				by MadBill
				Well, as far as going the "skinny snows" route with 16"s, about the only alternative to stock that would come close is a 185/60 x 16"(if you can find one), giving 815 revs/mile vs. the stock 811, but two sizes down is a little shaky for load capacity...
				Re:  (MadBill)
				Posted: Wed Nov 03, 2004 10:28 am
				So basically, I should stick with 205/55/16 for stock wheels?
				Re:  (ragingfish)
				Posted: Wed Nov 03, 2004 10:49 am
				by MadBill
				That's certainly the safest bet, Mike.
				Re:  (MadBill)
				Posted: Wed Nov 03, 2004 10:50 am
				Thank you Señor Bill!MADBILL FOR PRESIDENT!
				Re:  (ragingfish)
				Posted: Wed Nov 03, 2004 11:07 am
				by MadBill
				Aw, shucks. Thanks, Mike...but I'd have to be native-born!
				Re:  (MadBill)
				Posted: Wed Nov 03, 2004 11:09 am
				Well...I know a guy who can make some documents...
				Re:  (ragingfish)
				Posted: Wed Nov 03, 2004 11:20 am
				by MadBill
				I dunno; the oposition usually gets into some pretty detailed background checks! Not sure if I'd want that to happen, JIC....
