				Who thinks I should buy these for my Vibe?
				Posted: Wed Jul 07, 2004 10:21 pm
				by Smokin' Rubber
				"19X9 rear 19X8 front. Offset 42 5/5M PCD 100/114.3 GM with Nitto 245/35ZR19 93W on front and 275/30ZR 96W. (2003). 300 miles on tires." For only $100 lolAnd yeah I know that I have a front wheel drive so it makes no sense to have larger rear tires but oh well. Hehe and now I can be like MadBill and have 270's on my car
				Re: Who thinks I should buy these for my Vibe? (Smokin' Rubber)
				Posted: Wed Jul 07, 2004 11:07 pm
				by ebslopp
				I think you should buy those for MY vibe! Those are nice. You'd be a fool not to buy them.
				Posted: Wed Jul 07, 2004 11:08 pm
				by nismo
				WOW! Those are some beautiful wheels. They look like Racing Harts
				Posted: Thu Jul 08, 2004 12:08 am
				by Mr. Poopypants
				If you don't buy them I will.  GIVE ME THE SELLER'S INFO!
				Posted: Thu Jul 08, 2004 1:26 am
				by Jahntassa
				Hell, for that price, go for it! I think with 19's you might need to get your speedo recalibrated though...
				Re:  (Jahntassa)
				Posted: Thu Jul 08, 2004 2:48 am
				by ebslopp
				Quote, originally posted by Jahntassa »Hell, for that price, go for it! I think with 19's you might need to get your speedo recalibrated though...Is that possible? I didn't think we could calibrate the speedo.
				Posted: Thu Jul 08, 2004 6:09 am
				by dsegundo
				You'd have to....19's are cutting it a tad close though.
				Re:  (dsegundo)
				Posted: Thu Jul 08, 2004 9:08 am
				by Smokin' Rubber
				well its not that the  19's in 35 ratio wouldn't fit its the fact that its 19 and its 275 wide lol, altho MadBill managed to fit 275 18's so I think I should be ok
				Re:  (Smokin' Rubber)
				Posted: Fri Jul 09, 2004 6:52 am
				by ALi3N
				if you are only talking about wheel diameter it would have no affect on the speedometer reading, what would do it is a different outer tire diameter. Tire width should not have an affect on how the speedo reads either, however that will adversely affect your turning radius.
				Re:  (ALi3N)
				Posted: Fri Jul 09, 2004 2:08 pm
				by Smokin' Rubber
				Quote, originally posted by ALi3N »if you are only talking about wheel diameter it would have no affect on the speedometer reading, what would do it is a different outer tire diameter. Tire width should not have an affect on how the speedo reads either, however that will adversely affect your turning radius.well technically if the diameter of the wheels + tires is larger than whatever the stock is the speedometer will be off (and the offset will be worse at higher speeds) due to the fact that the larger the diameter a wheel/tire is the less it has to rotate to go one mile, this means that your speedometer will be showing a lower speed than what you are actually going.as for adversely effecting turning radius, this is only and issue if the new width rubs up against the wheel well before it actually hits the mechanical barrier that prevents the wheels from turning any farther. Since the front wheels are only 245 in width there should be no problems with the turning.
