Page 1 of 2
CF Hood Scoop now operational
Posted: Wed Jul 07, 2004 3:18 pm
by Celtic_Curse
Well she works now heres the link to the pics.
http://forums.genvibe.com/zerothread?id=10996
Re: CF Hood Scoop now operational (Celtic_Curse)
Posted: Thu Jul 08, 2004 2:41 pm
by Celtic_Curse
Here are the pics Another Another What ya'll think?
Posted: Fri Jul 09, 2004 1:26 am
by Mr. Poopypants
NICE!!! But, what about rain? I would think you would want to keep the engine compartment dry most of the time.
Posted: Fri Jul 09, 2004 1:08 pm
by engine1
(removed), hack job. Sorry, not functional.
Re: CF Hood Scoop now operational (Mr. Poopypants)
Posted: Fri Jul 09, 2004 3:23 pm
by Celtic_Curse
Rain won't affect anything inside the engine bay water gets in there all the time from the front grills and anywhere else it can get in. It vents overtop the back of the engine making the engine bay cooler like the celica.
Posted: Fri Jul 09, 2004 7:09 pm
by Smokin' Rubber
I would love to fabricate a ram air for my car but I'd nee to borrow some aluminum, a metal fabrication shop, and I would need a test car (no way in hell am I going to test this on my car with the chance of screwing it up lol)Btw you might think about adding some plastic molding to direct the cold air to certain parts of the engine and have little channels to direct the water off to the side
Posted: Sat Jul 10, 2004 2:57 am
by Merzbow
I like it The cuts in the hood look nice and even too, Good job. Atleast now no one can be a b*tch and say it's not functional
Re: CF Hood Scoop now operational (Merzbow)
Posted: Sat Jul 10, 2004 4:09 am
by Mavrik
You going to make it funtional with your intake?
Re: CF Hood Scoop now operational (engine1)
Posted: Sat Jul 10, 2004 5:42 am
by celica girl
How can you say it's not functional?It helps cool the engine. That's functional enough for me.
Re: CF Hood Scoop now operational (celica girl)
Posted: Sat Jul 10, 2004 12:45 pm
by Smokin' Rubber
Well technically he is right it IS functional for his purpose. He never said he would be using it for ram air which it is not setup for.
Re: CF Hood Scoop now operational (Smokin' Rubber)
Posted: Sun Jul 11, 2004 1:18 am
by engine1
Sorry i will choose to disagree, This a a hack-job. The cut-out job is uneven, was a templet used (doesn't look like it); the mounting of the scoop on top is off center, and the cheap grating used underneath screams trailer park. If you are going to modify an expensive body panel to acheive both cosmetic and functional purposes please get a professional to help you. This was not a professional install, i could do no better my self, but I am not a body guy, you should have waited and spent more money for a shop to do the install. BTW we all have two huge holes in the front of the car which bring cool air past the motor, seems pretty adequate?! This install of Celtics will only serve to make that insulation inside the hood look like shredded wheat in about a month, which could in fact start a car fire, thereby increasing the overall temp under the hood. Not functional AT ALL!!
Posted: Sun Jul 11, 2004 1:22 am
by Smokin' Rubber
man thats a bit harsh...and what do you mean the grating screams trailor park? grating is grating, and who the heck cares what the grating looks like on the inside of the engine bay. Heck why didn't pontiac line the engine bay with pure gold since it is the best for heat deflection and it looks nice!? We'd only have to pay alittle more for that...
Posted: Sun Jul 11, 2004 1:34 am
by engine1
It maybe harsh but why cut up your car if it looks worse and has its value severly reduced by cutting and hacking. I work in this industry everyday and see guys spend as little as possible doing a job like this because they dont realize the work involved. Just the mounting, coulnd't even be bothered to get out a measuring tape. And the cut outs are totally uneven and different sizes. I stand by what I say. This is a perfect example of why body work cost the money it does, its not easy. Do it right do it once. What do you think the dealer is going to be thinking to himself as he is deciding your trade value, 'Well gotta replace the hood, that 1500 off what i was going to offer'. BTW if you don't care what the job looks like in the end, why start? Every one of my installs especially the oil guage, looks like a pro did it. I used shrinkwrap over my (removed) connectors, blocked the vent in such a way that it could be functional again, routed oil line pretty much out of sight in the engine bay. If you want to show it off why not have it look great from every angle, you get a better feeling about what you have done.
Posted: Sun Jul 11, 2004 1:46 am
by engine1
I don't mean to be hard on you Celtic but you could have got that laid out and cut out by a GOOD body shop for 100 bucks, it would have been money well spent.
Posted: Sun Jul 11, 2004 3:31 am
I think that the pics in the other thread give the illusion that the hood scoop is not centered, but that it is just due to the slight angle the picture was taken from. I took one of the pics and drew some lines on it, it looks to me like the scoop is well centered.
Re: CF Hood Scoop now operational (joatmon)
Posted: Sun Jul 11, 2004 3:50 am
by VibeChick
Yes, it is centered, and it was done by a body shop. He didn't go in there hacking his hood up himself. I think we get the point now engine1, it's not your taste. Don't be so rude about it.
Posted: Sun Jul 11, 2004 4:40 am
by wicked1981
You dont have to be rude to get a point across.Not cool
Posted: Sun Jul 11, 2004 9:36 am
by Merzbow
Man, f*ckin chill out! Maybe it's sole purpose was for appearance but people like you got on his @$$ because it was non functional so he thought he had to make it functional in order to regain respect...Now that it works you still arn't happy.The chances of the insulation catching on fire is probably about 0.000000000000000000000009. Si think the hood scoop looks awsome and I don't understand what your problem is. It's not off centered either just open your eyes a little man.
Posted: Sun Jul 11, 2004 10:34 am
by Celtic_Curse
Well thanks for the remarks there engine1, I'll let the folks at international collision (the most respected custom body shop in town ) know they did a hack job. Everyone is entiled to their view, it is functional for my purposes and should I go with a TMIC like someone recommended it will be way more than functional, I don't know where your getting your facts about what is and what isn't functional, but to direct airflow in to the engine like I wanted is 100% completely functional, and as for the dealer wanting to take money off my trade in is dumba** they want to sponsor the car now, and judging fom the constant attention the car recieves because of its uniquenss I'm sure I'll get plenty when I sell it,to each his own.
Posted: Sun Jul 11, 2004 3:56 pm
by blk182@n7
I think its kick @$$, is there any talk about painting it to match? or do you like it to stand out?
Re: (Celtic_Curse)
Posted: Sun Jul 11, 2004 11:19 pm
by celica girl
The shop that Celtic got his scoop installed at does a large number of the show cars here in the city. Including mine. They have done plenty of body work for me. You tell me if my car looks like a hack job. You need to stop being such a jackass. The center post on the scoop itself is a little off. But it is centered perfectly. Stop being a hater and try being creative and do something original to your car. Stop being a chicken (removed) dare to be different.Here's some pictures of the hack job the bodyshop did on my car.
Re: (celica girl)
Posted: Sun Jul 11, 2004 11:25 pm
by Mr. Poopypants
OK, I have a great idea. Everyone just knock the crap off. In case you have not noticed, a ton of good members have been dropping like flies because of this type of arguing and bickering. There is no way that everyone will like everything that anyone does to their car, if you don't like it, just say it's not your thing and let it go at that. When it gets to the point of personal attacks, maybe you have gone a bit too far. If you feel like discussing something further, use the IM feature, that's what it's here for. So, now I am finished ranting. Remember, a little self control goes a long way.
Posted: Sun Jul 11, 2004 11:37 pm
by AKLGT
wow! you have a bad day or something?at first, i must admit, i didn't like the scoop. i like monotone. but now after looking at it with his color scheme, it goes well. to add that he got it functional, makes it even better. and i think it's pretty gutsy of him to do this.that's fine if you don't like something, but you really don't have to be such a jerk about it. knowing both jackie and ivan, i highly doubt the bodyshop that worked on his car does a "hackjob" in the least. and if you even looked at the other threads as EVERYONE else has pointed out, the pics MAKE the scoop LOOK off center but it is not. personally, i'd not have done it myself, but that's me. or if i had, i'd paint the scoop. if ivan hadn't gotten it from jackie, i was considering it myself. and i know i sure as hell wouldn't put up w/ anyone calling my car crap or saying the rude things you did. it's his car. if he likes it, then that's what matters.btw, when people ask "what you think?" it's more an invitation to give your opinion if you like it or not. not rip it, the job, anyone involved with it apart. so i guess my review or YOUR review would be 2
Re: (Mr. Poopypants)
Posted: Sun Jul 11, 2004 11:42 pm
by celica girl
People just need to stop pretending that they know what they are talking about. I don't mean you Mr. Poopypants.Thanks for that Hope.
Re: (celica girl)
Posted: Sun Jul 11, 2004 11:59 pm
by Mr. Poopypants
I know you didn't mean me, I just think common courtesy is lost sometimes.
Re: (NSimkins)
Posted: Mon Jul 12, 2004 12:44 am
by russ257
celtic i like the scoop. looks good. just curious what all do you have done to your car to have the dealership thinking about sponsering it?
Posted: Mon Jul 12, 2004 6:27 am
by AKLGT
ya, i think we all need to take a breather. if you haven't noticed, but the forum is very slow.... a lot of the old members don't post much anymore. granted i was gone for 10 days, but there isn't much for me to post or respond to really. my numbers have dropped considerably.
Re: (trdvibe)
Posted: Mon Jul 12, 2004 7:18 am
by celica girl
Cuz you have been Moonlighting on VMX.
Re: (celica girl)
Posted: Mon Jul 12, 2004 8:02 am
by AKLGT
ya ya ya! LOL. besides, i gotta keep up hopetown and my other way off topic forum!
Re: (trdvibe)
Posted: Mon Jul 12, 2004 1:02 pm
by Merzbow
How much was the scoop itself separetely, and how much was it to cut out the hood?
Posted: Mon Jul 12, 2004 3:04 pm
by Celtic_Curse
Hood scoop was $100 from Celicagirl, install plus cutting the hood was $230, It's a VIS carbon fibre scoop off of a Celica Carbon fibre hood. Thanks again to CelicaGirl.
Re: (russ257)
Posted: Mon Jul 12, 2004 3:06 pm
by Celtic_Curse
Quote, originally posted by russ257 »celtic i like the scoop. looks good. just curious what all do you have done to your car to have the dealership thinking about sponsering it?It's what I've done so far and what I am planning to do that has their interest peaked, you ask enough people to sponsor you you usually get some takers.
Re: (Celtic_Curse)
Posted: Tue Jul 13, 2004 8:15 am
by Merzbow
I would love yo try and get mine sponsered, however it's in my mom's name and she freaks whenever I buy something for the car. So if nothing else I'm going to have to wait until the warentee's up since that is her major excuse not to buy anything. I'll bet alot of people turn their heads when you roll by don't they? especially with those cute grills ( I have the grills also and everyone around here stares at the car)
Re: (Merzbow)
Posted: Thu Jul 15, 2004 12:54 pm
by Celtic_Curse
The car is looking pretty good my wife is getting suspicious though so got to cool it for a while before she gives me the old boot.
Re: (Celtic_Curse)
Posted: Thu Jul 15, 2004 12:55 pm
by AKLGT
Quote, originally posted by Celtic_Curse »The car is looking pretty good my wife is getting suspicious though so got to cool it for a while before she gives me the old boot.ha ha ha! ya, that's not so much fun
Posted: Thu Jul 15, 2004 2:48 pm
by Celtic_Curse
If she opens the hood I'm toast, or she'll commit me to mod rehab
Re: (blk182@n7)
Posted: Thu Jul 15, 2004 3:06 pm
by savedbyzero
I guess I don't see what's so "functional" about it. No ram air, and very little engine cooling, I would think.But hey, whatever...I'm not one for sticking plastic or "carbon fiber" on my car.At least the effort was made to make it "functional". Not trying to be a jerk, but it does look kinda hacked to me. Even respectable body shops can hack jobs. I think it could have been done a lot cleaner. Paint it the same color as the body, and it may look a little more factory.
Re: (savedbyzero)
Posted: Fri Jul 16, 2004 2:14 am
by Mr. Poopypants
Zero, we covered this already, just let it go.
Re: (savedbyzero)
Posted: Fri Jul 16, 2004 3:47 am
by wicked1981
Quote, originally posted by savedbyzero »Not trying to be a jerk, but it does look kinda hacked to me. So it comes natural?
Posted: Fri Jul 16, 2004 3:57 am
by NSimkins
Okay gentlemen, I don't want something else to start up over this topic. Keep it cool please.
Re: (NSimkins)
Posted: Fri Jul 16, 2004 5:33 am
by wicked1981
My bad. I just thought we had talked about this posts be4. No need to restart things back up. I appologize.
Re: (wicked1981)
Posted: Fri Jul 16, 2004 5:58 am
by AKLGT
honestly, i don't really think that ivan cares about some of the opinions. he was excited and wanted to share in his excitement. i'm glad that he did.
Re: (wicked1981)
Posted: Fri Jul 16, 2004 12:14 pm
by Celtic_Curse
Your right TRD I don't really care about some of the opinions, I posted, I shared, and I asked for opinions. I'm a grown up (I think) so words on a computer screen don't generate emotion for me. People are free to post what they think, just remember that constructive critiques are sapposed to help. I'm happy with my little mod you don't like the mod cool for you. Just my 2 cents.
Re: (Celtic_Curse)
Posted: Sat Jul 17, 2004 12:14 am
by Mavrik
Do you plan on modifying your intake to work with the new operational hood scoop? I know I asked before but I didn't see an answer..
Re: (Mavrik)
Posted: Sat Jul 17, 2004 4:01 am
by AKLGT
no i don't think that he is. he's got a full cai. but i know he's got some other things up his sleeve and he won't tell! ha ha ha! we'll find out ivan! and i hope you get your red dress ready and your matching pumps. cause when jackie whoops your (removed) next fri, i can't WAIT to see that photo online!!!!! ha ha ha! you better get some NOS if you wanna beat her! cause cool air over your engine ain't gonna help you on the track against her!
Posted: Sat Jul 17, 2004 3:05 pm
by Celtic_Curse
I have this strange suspicion that no one is rooting for me to win. Your right Hope I have no plans on making my CAI work up to the scoop, I'm saving my pennies for a twin turbo setup.
Re: (Celtic_Curse)
Posted: Sat Jul 17, 2004 3:06 pm
by AKLGT
lol. well, i want to see that pic!!!!
Re: (trdvibe)
Posted: Mon Jul 19, 2004 2:04 pm
by Celtic_Curse
No one still has told me what I get if I win. The car is out of commision though broke something tonight playing with a new toy, hopefully it's up and running by Friday.
Re: (Celtic_Curse)
Posted: Mon Jul 19, 2004 11:02 pm
by celica girl
Tell us what you want if you win.... we'll decide if it's fair or not.
Re: (celica girl)
Posted: Tue Jul 20, 2004 10:37 pm
by ALi3N
I think the scoop as it is now is a good starting point. Personally i would have gotten the off-centered Ram-Air scoop that is positioned over the airbox, but that is a mater of personal taste. I do worry that if you decide down the road that you do not like it you will have to spend upwards of $600 for a new painted hood. I have no complaints about the look or installation of your scoop, good job.
