3000 RPM or lower
Posted: Wed Jul 07, 2004 8:09 am
by scherry2
Well, I just watched a wrecker service haul my vibe to the dealer, I was mounting my neons today and about 4:00 P.M. I was going to run to the store and my check engine light came on when i started it(not flashing). and it was Idling a little high. I put it in drive and around 2000 to 3000 RPM it started to cut out like it was starving for gas, I cleared the code and restarted it and no change. I'll call the dealer tomorrow and find out the problem. I never even got my neons hooked up, just got them mounted.
Re: 3000 RPM or lower (scherry2)
Posted: Wed Jul 07, 2004 8:11 am
by ragingfish
Weeeeeeird....I'm guessing you don't have a scanner to know what the code was?
Re: 3000 RPM or lower (ragingfish)
Posted: Wed Jul 07, 2004 8:12 am
by scherry2
no, I wish i did though. good thing its under warranty.
Posted: Wed Jul 07, 2004 8:14 am
by VibeChick
Sounds exactly like what happened when Phil's MAF sensor went belly up.
Re: 3000 RPM or lower (silverawd26)
Posted: Wed Jul 07, 2004 8:22 am
by scherry2
Quote, originally posted by silverawd26 »Sheldon, were for poking around the engine bay at all and maybe bumped something?that was the first thing i thought but no, I wasn't near any wires or vacumn lines. I was working on both sides and under the front. I even checked the plugs and vacumn lines by the CAI and i wasn't even near those areas.
Posted: Wed Jul 07, 2004 12:32 pm
by Jahntassa
Hopefully it's just a sensor thing. You'll get it back soon!
Re: (Jahntassa)
Posted: Wed Jul 07, 2004 11:50 pm
by Mavrik
I'm betting its the MAF sensor, sounds exactly what mine was doing... and if I am correct in this, no one will have a part and will take a few days to get one. I ordered one on friday before the meet and it came in weds of the following week. Never did find out what happened to mine.
Re: (Mavrik)
Posted: Thu Jul 08, 2004 1:31 am
by scherry2
Quote, originally posted by Mavrik »I'm betting its the MAF sensor, sounds exactly what mine was doing... and if I am correct in this, no one will have a part and will take a few days to get one. I ordered one on friday before the meet and it came in weds of the following week. Never did find out what happened to mine.Thats what it was and the service rep said it probably happend when i installed the CAI. but they covered it under warranty and they had one on hand.
Re: (scherry2)
Posted: Thu Jul 08, 2004 2:11 am
by ragingfish
Quote, originally posted by scherry2 »Thats what it was and the service rep said it probably happend when i installed the CAI. but they covered it under warranty and they had one on hand. Hasn't your intake been in for a while now?
Re: (scherry2)
Posted: Thu Jul 08, 2004 3:28 am
by Mavrik
Quote, originally posted by scherry2 »Thats what it was and the service rep said it probably happend when i installed the CAI. but they covered it under warranty and they had one on hand. Yeah exactly what I "did" to mine but I bet you can't remember how you "might" have damaged it either huh... wonder why yours took so long to act up though... hah and you took it there with the CAI in right? I ripped mine out to do that as I told ya at the meet.
Re: (ragingfish)
Posted: Thu Jul 08, 2004 4:05 am
by scherry2
Quote, originally posted by ragingfish »Hasn't your intake been in for a while now?Yea about a year or more ago, I might have damaged it when i did the install. It just took a little longer to go bad.the dealer has known I have the CAI so why hide it.I thought it was quite nice they covered it under warranty even the towing.I hope eveyone enjoyed the guessing game, your pie is in the mail.
Re: (scherry2)
Posted: Thu Jul 08, 2004 12:30 pm
by Kissfan79
Anyone know how much a MAF sensor would cost to buy? My warranty is expired (comming up on 41,000 miles ) and was just curious in case I ever had to replace it myself.Jim
Re: (Kissfan79)
Posted: Thu Jul 08, 2004 8:09 pm
by Mavrik
Its over $100 CAD...
Re: (scherry2)
Posted: Fri Jul 09, 2004 3:10 am
by AKLGT
question: when was the last time you cleaned the filter? i know on my tundra i learned that the filter, if not cleaned well or properly, can send the oil and junk up the intake tube and screw up the maf. i usually clean mine every 15K miles even tho it says you don't have to do it for 25-30K miles. and if it's not cleaned and gets dirt and grime that some particals will pass thru the filter and also mess it up.
Re: (trdvibe)
Posted: Fri Jul 09, 2004 5:15 am
by scherry2
I've cleand it 2x and i have 12,000 miles. good idea though.
Re: (Kissfan79)
Posted: Fri Jul 09, 2004 11:26 am
by ragingfish
Quote, originally posted by Kissfan79 »Anyone know how much a MAF sensor would cost to buy? My warranty is expired (comming up on 41,000 miles ) and was just curious in case I ever had to replace it myself.JimList is about $180, GMPD is listing it at $83.
Posted: Wed Jul 14, 2004 12:02 pm
by victorzhu
My new vibe was taken to dealer for repair (at about 256 km). They told me there was a defect sensor(can't remember the name), but seems we got the similar problem. The engine always work at more than 3000 RPM.I leave my vibe at the dealer for 6 days, but they did give me a Chev. Malibu (like new, also have 200km on it), which I found out the have a better control. I guess this is a really weak part for our vibes.
Re: 3000 RPM or lower (victorzhu)
Posted: Wed Jul 14, 2004 10:06 pm
by goodvibe
scherry2, It's best to wait till atleast 20k mi. to clean the filter unless it's real dirty where you are. Gauze fiters don't filter as well as stock(well enough) but do better as they get dirty. You won't see any flow reduction for 20k mi. If your sensor acts up again after a filter cleaning (and sitting out for a day), you can try to clean it with contact cleaner or carb cleaner.
Re: 3000 RPM or lower (goodvibe)
Posted: Wed Jul 14, 2004 11:46 pm
by scherry2
cool! thanks for the tip I've never run a K&N type filter before. ya learn something new every day.
Posted: Wed Jul 14, 2004 11:58 pm
by goodvibe
We all learn the hard way unfortunately. Raises hand. I took a new K&N drop in out off the carton and put it directly into my intake and fouled the MAF in a day. Next oil filter will sit out of its seal to tac for a while before I install. By the way, I bought a spare MAF on ebay for $25 bucks just in case. Came off a low mi. totaled RAV4. My original works fine after I cleaned it but it's nice to have a spare. I'll just use it in my AEM intake when I install.
Posted: Tue Jul 27, 2004 7:54 am
by Cidderiforous
sounds like the problem I'm having right now....4000 rpm and lower ...but I took the car to Autozone and they hooked up the scanner to it, and it said cylinder 1 and 4 misfired... it was raining when the problem started, and I'm thinking I got water in my CAI and that might be causing the misfiring, but I would think that the water should've evaporated by now, and after 4000rpm, it runs right I'm afraid to take it to the dealer though, but I'm getting close to the end of warranty.....28000 miles
Re: 3000 RPM or lower (Cidderiforous)
Posted: Mon Aug 23, 2004 8:47 am
by Cidderiforous
well I took it to the dealer. been in and out of the dealership for the past 3 weeks...they can't seem to find the problem.....trouble is...it only happenes when I turn...they hooked up an onboard diagnostic computer and had me drive around for a couple days..of course I couldn't get the damn thing to do it then....anyway....I still wonder if it might be the MAF sensor??
