amp wiring
Posted: Sun Jul 04, 2004 1:34 am
by flyby
anybody know which wires are which coming from the amp? REMOTE WIRE??? M&T package amp
Posted: Sun Jul 04, 2004 12:30 pm
by Jahntassa
Are you talking about the turn-on wire to make the amp wake up? I believe it's the single wire in the second harness to the radio, you need to tap into that to make the M&T amp turn on.
Re: (Jahntassa)
Posted: Sun Jul 04, 2004 3:00 pm
by ragingfish
Quote, originally posted by Jahntassa »Are you talking about the turn-on wire to make the amp wake up? I believe it's the single wire in the second harness to the radio, you need to tap into that to make the M&T amp turn on.Nope. That's labeled as "Mute Control." It never gets used for anything AFAIK.The remote turn on lead for the amp is in pin B3 of the main harness. It actually has two thin black wires coming from it. Tap into either one.
Posted: Sun Jul 04, 2004 3:56 pm
by Jahntassa
See..this is why I try to point you towards things Mike... Heh.Yes, follow his reccomendation!
Re: (Jahntassa)
Posted: Sun Jul 04, 2004 11:47 pm
by flyby
hamiltonaudio is right. thank you
Re: amp wiring (flyby)
Posted: Mon Jul 05, 2004 12:08 am
by MoonDogg
Yes I know exactly what wire you need to tap into .. I messed with mine for 2 hrs trying to figure it out... if your looking at the harness (unpluged) and the clip is at the top its the third wire from the bottom left on the bottom part... its a solid black wire. after I hooked my remote wire to it everything worked great.. if you cannot find it I will take mine apart and try to get pictures of it and post it... Let me know if this helps... Later...
