Power Locks,Mirrors help Me Please
Posted: Tue Jun 29, 2004 9:41 am
by BlueVibe
My remote pad for the locks don't work. Also the power mirrors work but the switch won't allow the mirrors to go up. I was just wondering if anyone had been having this problem.
Re: Power Locks,Mirrors help Me Please (BlueVibe)
Posted: Tue Jun 29, 2004 10:08 am
by Devlop
The only thing I can think of is a fuse. I've seen many cars that have the mirrors and door locks on the same fuse. Try that.
Posted: Tue Jun 29, 2004 10:13 am
by BlueVibe
The fuse are all good checked them with my fuse tester
Re: (BlueVibe)
Posted: Tue Jun 29, 2004 10:34 am
by Devlop
Hmmm....sorry, that's my only idea. hopefully, your still under warranty and you can just take it in.
Posted: Tue Jun 29, 2004 10:44 am
by ragingfish
Do both remotes not work? If it's only one, then maybe the battery is defunct. If it's both, they may not have been properly programmed at the factory (or dealer) and just need to be reprogrammed.As to the mirrors, if it's just the up part of the switch not working, and both mirrors won't go up, switch might be defective.But, are you sure the L/R switch is on L or R, and not in the middle? When in the middle, it acts as an OFF switch and prevents you from accidentally moving the mirrors.
Re: (ragingfish)
Posted: Tue Jun 29, 2004 10:48 am
by scherry2
Quote, originally posted by ragingfish »As to the mirrors, if it's just the up part of the switch not working, and both mirrors won't go up, switch might be defective.this would be my guess. we see it plenty of times at work.
Posted: Tue Jun 29, 2004 11:12 am
by BlueVibe
The remotes and the inside buttons dont work either. When switching between the two mirrors left, right, and down work but no up. I made an appointment to take it in
Posted: Tue Jun 29, 2004 11:25 am
by ragingfish
Question.Can you only not unlock the doors inside with the button?If they'll lock, but not unlock, that means at some point the remotes work, and the doors will locked. You cannot use the interior buttons to unlock the door if it has been locked with the remote. It must be first unlocked with the remote to enable the interior buttons.If it won't lock or unlock, I'd venture to say it's a fuse...
Posted: Wed Jun 30, 2004 6:55 am
by BlueVibe
no, now the entire locking sytem is out and I have to use my keys
