K&N typhoon part number?
Posted: Tue Jun 29, 2004 8:02 am
by fancynewwheels
I have decided to get the K&N typhoon Short Ram for my vibe 04 non-GT (Base)But, nobody has part numbers so my supply guy can't order it... Anybody kind enough to post the part number for me? PLEASE!!! I can't go with Injen CAI because I live in Canada, and that might suck up a little too much water.... ie. snow on the ground (or so a guy at the track was telling me...)
Re: K&N typhoon part number? (fancynewwheels)
Posted: Tue Jun 29, 2004 10:42 am
by wicked1981
According to K&N site there is only air filter and drop in filter for the Vibe no typhoon. http://www.knfilterchargers.co....aspx
Posted: Tue Jun 29, 2004 11:59 am
by fancynewwheels
For the 2003 they have one.. #69-8600 and the letters at the end are for the color. Maybe these fit the 04s? Does anybody know? I phoned one store and they can get one for the 04 and have one at another store. I just would like to save a few dollars through my parts man.. Thanks everybody!
Posted: Wed Jun 30, 2004 2:50 am
by fancynewwheels
The 03 and the 04 are exactly the same for K&N Typhoon... Thanks to Canadian Tire for that one... (Amazing they knew that but nobody else did)
Posted: Wed Jun 30, 2004 3:17 am
by AKLGT
for the base models, they are not any diff. only the gt models are different due to a smog pump added in the 04 models.
Re: (trdvibe)
Posted: Fri Jul 02, 2004 10:26 pm
by FusionVGT
Actually the same part number is used for the GT also. The air pump doesn't come into play with a short ram.
Re: (FusionVGT)
Posted: Thu Jul 08, 2004 2:30 am
by AKLGT
sorry. i meant that the engines are the same. so the short ram would not change at all. only the gt engines were diff for 03 and 04. and now the 05 is diff too in hp. but i believe the smog pump is the same like the 04.
Re: (fancynewwheels)
Posted: Fri Jul 09, 2004 1:05 pm
by engine1
Too bad there is no Lordco Parts in AB yet. How much those knuckle heads at C.T. charging you?
Posted: Sun Jun 26, 2005 7:15 pm
by hamidlmt
I've installed the K&N short ram intake on my wife's Vibe and noticed a quick ticking sound at idle after 10-15 minutes of driving. Any thoughts of what it might be?
Re: (hamidlmt)
Posted: Sun Jun 26, 2005 8:51 pm
by Mr. Poopypants
This has come up before, it is probably the MAF, this happens, but now that you have an intake installed, it doesn't muffle the sound so now you notice it.
