A/C without the A/C button
Posted: Sat Jun 26, 2004 1:11 pm
by BlackBerry
Hi all,I wasn't sure where to ask this, so I thought I would start with the locals first. When I set my air selector to windsheild does it automatically turn on the A/C even though the light on the A/C button is not lit? @ reasons I believe this is so: 1) the air that blasts me in the face get freakin' cold! 2) the egines rev's change much the same way as when I turn on the A/C. What do you think?Peace,BB
Re: A/C without the A/C button (BlackBerry)
Posted: Sat Jun 26, 2004 1:47 pm
by ragingfish
Yes. When the dial is in either defrost mode (windshield/floor or direct windshield) it does activate the A/C compressor. The air conditioning system, by design, dehumidifies air. Thus, in order to properly defrost/defog windows, the A/C kicks in to take any humidity out of the air.
Re: A/C without the A/C button (ragingfish)
Posted: Mon Jun 28, 2004 10:38 am
by Mavrik
Yup that is true. The air won't be cold if you turn the dial towards heat.
Re: A/C without the A/C button (Mavrik)
Posted: Wed Jun 30, 2004 12:42 pm
by BlackBerry
Thanks for the responses! It seems like an ineffeceient design, doesn't it? The A/C died in my Grand Prix before I got rid of it and the windsheild defrost still worked. I believed that simply the air moving across the condesnation cleared it up without the dehumidifying effect of A/C. As well, while it is true I can turn the tempurature setting warmer all that does is allow more warm air from the heater core to mix in but still operates the A/C components (compressor, etc...) Seems odd that I cannot run the defrost across the windsheild without kicking on the A/C. Oh well, I still love my Vibe! BB
Posted: Wed Jun 30, 2004 12:59 pm
by ragingfish
Quote, originally posted by BlackBerry »Seems odd that I cannot run the defrost across the windsheild without kicking on the A/C. Oh well, I still love my Vibe! You actually can disable that with a little minor surgery...
Posted: Wed Jun 30, 2004 1:10 pm
by BlackBerry
Thanks Mr. Fish! I just found this,http://home.comcast.net/~vibeowner/hidden.htmtalks about discoonecting a wire to disable this "feature."Interesting.BB
Posted: Wed Jun 30, 2004 1:37 pm
by Mavrik
the reason its cycled when on defrost is to remove moisture from the air so its not thrown onto the window and fogging it up. It also keeps the A/C working, so it doesn't seize up due to inactivity.Remember, sure you can unhook things... but they were designed that way for a reason.
