FI in a AWD?
Posted: Sun Jun 20, 2004 8:37 am
by theimportscene
has anyone installed that bolt-on SC on the AWD vibe...?cuz AWD + FI = eternal bliss
Re: FI in a AWD? (theimportscene)
Posted: Sun Jun 20, 2004 10:21 am
by Devlop
I can't remember if anyone here has, but greenfire over on matrixowners.com has and I don't think he's had any problems.
Posted: Thu Jun 24, 2004 12:51 pm
by greenfire
teamonkeys has a Supercharged AWD Vibe and I have a SC 4wd Matrix. No problems thus far. Only disavantage is that you can't not replace the header on the 4wd (easily) to gain more horsepower. The 4wd header is very restrictive. Other than that issue, no problems. Last I hear Teamonkey's car was running fine too.
Re: FI in a AWD? (greenfire)
Posted: Thu Jun 24, 2004 1:06 pm
by savedbyzero
Go turbo instead! Then you'd be talking some serious fun!
Posted: Thu Jun 24, 2004 1:09 pm
by AKLGT
can you port and polish those headers to make it more free flowing? prob cheaper too.
Posted: Thu Jun 24, 2004 1:17 pm
by theimportscene
all i know is your launches must OWN!!!
Re: FI in a AWD? (trdvibe)
Posted: Fri Jun 25, 2004 7:39 am
by futseal04
Quote, originally posted by trdvibe »can you port and polish those headers to make it more free flowing? prob cheaper too. Just FYI, you can't port and polish headers, but you can heads. Port and polishing just cleans up the intake tracks for less turbulant airflow. It is usually done in conjunction with a three-angle valve job that optimizes airflow around the valves. All this doesn't come cheap though....I looked at doing it for my Cobra, and it was about 800 a head.
Re: FI in a AWD? (futseal04)
Posted: Fri Jun 25, 2004 11:32 am
by greenfire
The problem with the 4wd header is that the first cat is part of the manifold. I tried to get a custom one made but the shop did not even want to attemp it. I thought about the possiblity of porting it out and relpacing that cat with a pipe. Would be expensive and difficult to find a shop that will try it.I was planning on going to the track tonight, but got rained out. My 1/8 mile time should be awsome. However, once the car gets into 3rd gear the show is over. Don't forget the 4wd is heavy and the gear ratios of the auto are slower. A GT/XRS will still be faster in the 1/4 mile.... But when it rains and snows...
