Clutch pedal noise (popping/knocking)
Posted: Sat Jun 19, 2004 4:38 am
by DavidPIL
Hi all...Ok, so we've had the pedal squeak, the clutch noise at idle when the pedal is pressed... Now over the past week I've began to notice a faint pop/knock sound and a noticable release of tension when pressing on the pedal no matter if the car is moving or not.This happens at about the last 1/4 of the pedal's movement which is usually further than I go in normal shifting.The feeling is almost like the pedal has even resistance to pressing on it till that point then it pops and then seems to move a little easier to the floor.Anyone have this? Any suggestions other than taking it in to try to fix it? I really don't like taking this car in for things because they never seem to know what they're doing. Any help would be appreciated.Dave
Posted: Sun Jun 20, 2004 11:03 am
by Jahntassa
I'm not well versed in the mechanical side...but I'm under the impression the Vibe has a hydraulic clutch...and that kinda behaviour sounds like something's wrong with the hydraulics (fluid low?).Sadly, I believe when a hydraulic clutch goes, there's no way to adjust it other than putting in a new one.. Someone can confirm/deny this though, as I'm not 100% sure.
Re: Clutch pedal noise (DavidPIL)
Posted: Tue Jun 29, 2004 6:47 am
by DavidPIL
ARGH!I can't find posts when I need em.. anyway, I know this probably means nothing to anyone but I read in a post where manually pushing the clutch actuator thing which is mounted on the transmission helped solve a few people's squeaks. I tried this and found that when it's pressed in (actually moved to the left), it moves up and down almost like it's free in the socket. Anywho. I assume this helps grease the fittings inside the rubber boot thing. This actually has eliminated my issue for now and the clutch somehow seems better, I dunno. Could this be a fitting that should be greased up more than it is? I think someone said something before about having their clutch fork greased. I'm assuming this is the part I'm talking about as well.Dave
Posted: Tue Jun 29, 2004 1:47 pm
by DavidPIL
The info on fixing the clutch noises was located on everythingcelica.com and the direct link is... http://www.everythingcelica.co...57282Apparently odd noises are quite common but easily remedied.Dave
