short shifter
Posted: Fri Jun 11, 2004 4:18 am
by marlborocowboy82
has any body put a short shifter on there gt yet?where did you get it a can't find one any where
Re: short shifter (marlborocowboy82)
Posted: Fri Jun 11, 2004 4:33 am
by wicked1981
Re: short shifter (wicked1981)
Posted: Fri Jun 11, 2004 4:47 am
by marlborocowboy82
thanxs
Posted: Fri Jun 11, 2004 6:51 am
by Devlop
I took and shortened the shaft on the shifter by about two inches. Not exactly a short shifter, but I like it a lot more than stock. TMW is supposed to be coming out with one for our cars soon and I think its gonna be better than the TRD one, but I'm not sure.
Re: short shifter (Devlop)
Posted: Fri Jun 11, 2004 7:16 am
by AKLGT
i want the TRD one but you have to do some cutting into your cubby that's under the shifter. that's what sucks.
Re: short shifter (trdvibe)
Posted: Fri Jun 11, 2004 7:38 am
by Devlop
Yeah, that's one of the reasons I haven't gotten one.
Posted: Fri Jun 11, 2004 11:15 am
by polaris1000
Same reason I did not get the TRD short shifter either. I would say that is a (removed) poor design. Looks like someone trying to push a product out the door before doing some good research on it.
Re: short shifter (polaris1000)
Posted: Fri Jun 11, 2004 11:25 pm
by Sub-Vibe-R
Sorry if my statement could look stupid, but why not just cut the stock shifter and buy an aftermarket shifter who does not need to be screwed and hold with allen screw?
Re: short shifter (Sub-Vibe-R)
Posted: Fri Jun 11, 2004 11:52 pm
by Devlop
That's basically what I did. I took the shifter assembly out and cut about two inches out of the shaft. I then welded the threaded part back to the rest of the shaft. I bought the TRD shift knob from someone who bought the TRD shifter. This works to an extent because of geometry, but it doesn't shorten the sifht as much as an actual short shifter.
Posted: Sat Jun 12, 2004 4:29 am
by goodvibe
Devlop, I haven't looked but if your welding, couldn't you extend the piece below the pivot to shorten the movement? 25% should only be 1/2" or so.
