Hopping at accelleration
Posted: Fri May 28, 2004 7:52 am
by Cmodee
When I accellerate, my Vibe tends to hop - ie instead of wheel slippage it hops. Is there anything that anyone can suggest that keeps this from happening? Is there anything you can buy that helps keep the rubber from slipping? Essentially I'm thinking of buying the supercharger but I'm worried that I won't be able to get anything out of it because the suspension / wheels won't respond.thanksGreg
Re: Hopping at accelleration (Cmodee)
Posted: Fri May 28, 2004 9:56 am
by cohocarl
I did a couple good launches that spun the tires for a ways before hooking up with my 5-speed.....I say couple because the rest of the time it would just give me major wheel-hop. Sounding and feeling like the front end of the car was going to jump out and leave me behind.I'm guessing our Corolla struts aren't up to snuff to handle the extra curricular activities.P.S. Welcome to the forum!!!
Re: Hopping at accelleration (cohocarl)
Posted: Fri May 28, 2004 10:26 am
by goodvibe
It's the motor moving on its mounts. Firming them up by filling or inserts takes care of it. The front mount is the most important to fix. Not recomended for autos as it causes the shakes.
Re: Hopping at accelleration (goodvibe)
Posted: Sat May 29, 2004 6:55 am
by satur9
http://www.ptuning.com energy suspension motor mounts(for the toyota matrix) work like a charm for like 40 bucks
Re: Hopping at accelleration (satur9)
Posted: Sat May 29, 2004 7:04 am
by Faultline
Quote, originally posted by satur9 »
http://www.ptuning.com energy suspension motor mounts(for the toyota matrix) work like a charm for like 40 bucksI am going to order these , and put them in when I put in a new clutch...can anyone vouge that these are working for them??
Re: Hopping at accelleration (Faultline)
Posted: Sat May 29, 2004 8:19 am
by Fialchar
Posted: Sun May 30, 2004 2:46 am
by Cmodee
Thanks everyone, I'll give those a try & see what happens!Greg
Re: (Cmodee)
Posted: Sun May 30, 2004 6:24 am
by Fialchar
Good luck, and keep us updated
