Syncronizer?
Posted: Fri May 28, 2004 6:50 am
by drummerdude
ok I have a delimma. I'm taking my car to the dealership on tuesday and i need to know what to tell them in tech terms.FYI, I have the GT (6speed) and yesterday the gears started grinding. It only happens when downshifting to second, and no other gears. Its fine when you shift through the gears going from stop(1st) to cruising (6th)... the only way you can down shift is if you set the shifter right on second gear and let it sit there for about 5 seconds and it will finally match and you can push it in with no grinding. any comments suggestions? I'm 1000 miles from the warranty going out.
Re: Syncronizer? (silverawd26)
Posted: Fri May 28, 2004 10:20 am
by goodvibe
G et it replaced under warranty. It's not right.
Posted: Fri May 28, 2004 2:09 pm
by drummerdude
Quote, originally posted by silverawd26 »Might want to have new syncro's and a new clutch installed. Should be about $1,500.00-$2,000 for parts and labor. I'll just let the dealer fix it under warranty for free and then i'll put aftermarket stuff after the warranty!
Re: Syncronizer? (drummerdude)
Posted: Fri May 28, 2004 2:33 pm
by Faultline
aren't warranties great!!....1000 miles! just in the nick of time!
Re: Syncronizer? (Faultline)
Posted: Sun May 30, 2004 3:50 am
by dmitri
my 2nd gear synchro's are garbage as well. It only grinds at really high rpm and i hit the limiter while im moving which i believe is at 8400!If i shift carefully though, i get used to it and it doesnt do it.
Re: Syncronizer? (dmitri)
Posted: Sun May 30, 2004 4:37 am
by drummerdude
Quote, originally posted by dmitri »my 2nd gear synchro's are garbage as well. It only grinds at really high rpm and i hit the limiter while im moving which i believe is at 8400!If i shift carefully though, i get used to it and it doesnt do it.Missing 2nd gear while racing too many times... would that do it?
Posted: Sun May 30, 2004 8:03 am
by dmitri
^^^^I doubt it because ive done it sooo many times....its not my fault though, because ive never really missed it, its just that i shift too fast and it wont go into gear and grinds at really high rpm. It just wont let me in unless i let the rpm's down. So instead, i shift slower but gas it between shifts and dump the clutch so my tires spin lol.
Posted: Sun May 30, 2004 12:56 pm
by goodvibe
drummerdude, what kind of gear oil do you use?
Re: Syncronizer? (goodvibe)
Posted: Mon May 31, 2004 8:15 am
by drummerdude
Quote, originally posted by goodvibe »drummerdude, what kind of gear oil do you use?I'm running all stock fluids... except for oil obviously.
Posted: Mon May 31, 2004 8:42 am
by goodvibe
After the fix try something better. A good fluid might help now but show em the problem and then try some royal purple or motul after the fix.
Posted: Mon May 31, 2004 10:24 pm
by drummerdude
so yeah, i just took the car in and i should hear something back by 4... I'll keep you all updated as to what the prob is.
Posted: Fri Jun 04, 2004 1:37 pm
by drummerdude
just an update, They ordered parts today, I went to get my radar detector out of my car yesterday after hours and i had sometime in the shop by myself, so i took the liberty of looking at the engine bay of my car while they had it up on the lift and the tranny pulled... frive axles and everything pulled off... i honestly think that with the proper tools and equipment it could be really easy to set up a v6 and tranny swap... there is seriously sooo much room in the engine bay... I would like to look into engine/tranny combo's that might work... but i have no idea where to begin!
Posted: Sat Jun 05, 2004 4:16 am
by satur9
scc put a supercharged camry solara v6 into a mr2 so yeah it can be done
Re: Syncronizer? (satur9)
Posted: Sat Jun 05, 2004 2:42 pm
by drummerdude
Quote, originally posted by satur9 »scc put a supercharged camry solara v6 into a mr2 so yeah it can be doneSorry if I'm just ignorant, I've heard about this supercharged v6 in a MR2... But what the hey is an MR2?
Posted: Sun Jun 06, 2004 2:47 am
by satur9
and most importantly it has the same 1zz engine as our cars(cept its mid mounted rear wheel drive).but it has a very tight engine bay. so if something fits there its a safe bet it will fit on other 1zz platforms.
Posted: Sun Jun 06, 2004 3:22 am
by scherry2
Quote, originally posted by drummerdude »Missing 2nd gear while racing too many times... would that do it? Quote, originally posted by dmitri »I doubt it because ive done it sooo many times... its not my fault though,boy if I had a $1.00 for every time I've heard that.
Posted: Mon Jun 07, 2004 2:00 pm
by marlborocowboy82
i have had the same problem with my tranny and the said it was my fork last time and i'm having it agian made for a bad race day having to wait for there to be a second gear taking it to the dealer thursday
Re: (marlborocowboy82)
Posted: Mon Jun 07, 2004 2:35 pm
by drummerdude
ok, well they are replacing the 2nd gear sychro and the entire 2nd gear... i'll have "Ginger" back tomorrow... Night all!
