hub sleeves?
Posted: Wed May 26, 2004 4:46 am
by Atomb
I had the wheels on my brand new Vibe upgraded at the dealership. Over the weekend I noticed some vibration at specific speeds and thought the wheels were just not balanced (properly). Brought it in today and i found out that the hub diameter is smaller than the hole in the rim and that they need to install a sleeve. Is this common or should i ask that they put new rims on which have the proper hole size for my hub?
Posted: Wed May 26, 2004 8:54 am
by Atomb
Thanks for the clarification/link.It's already cleared up as far as me not paying for them. Aside from this minor set-back i'm quite happy (so far) with the way this dealership has handled everything....it appears as though these rings are common...being plastic, will they need replacing down the road?
Re: (Atomb)
Posted: Fri May 28, 2004 2:56 am
by satur9
yeah they are common and cheap.they should last a while but check them out everytime you rotate tires to be safe.
