Question about the throttle cable assembly.
Posted: Sat May 22, 2004 9:58 am
by Kissfan79
Hey guys....just a quick question about the throttle cable assembly where it connects to the throttle body intake. If you have a friend hold the gas peddle down (or use a weight to hold it down as I did ), does the assembly the cable hooks to completely stop or does it still have room to move? When I press my peddle all the way down and then check the assmebly (as if I were revving the engine manually), the assembly will still move about 1/8-1/4"as if you could still open the throttle a touch more. Just curious....maybe I'll snap a picture or two to demonstrate tomorrow.Jim
Re: Question about the throttle cable assembly. (Kissfan79)
Posted: Sat May 22, 2004 11:25 am
by rodzombie
Hmmmmmm!!! Must check this!! Could mean making a bell crank to use at wide open throttle to really achieve wide open throttle. I wonder if the throttle position sensor will even let that happen, or if the ECU will try and counter act it moving that far. ( Like shutting ignition, or fuel pump off momentarilly.! ) It's something I'll look into!! Thanks for sharing this info Kissfan79.
Re: Question about the throttle cable assembly. (rodzombie)
Posted: Sun May 23, 2004 9:35 am
by satur9
nah they should all have some slack,weapon-r sells a bigger throttle rotor to tighten it up the celica one should work. i dont know how the cables go in the cruise control so ive stayed from it.they also provide less gas pedal modulation but some people wouldnt care about it.
Re: Question about the throttle cable assembly. (satur9)
Posted: Sun May 23, 2004 9:43 am
by Kissfan79
Ok.....here are the photos I wanted to take. The first is the throttle assembly "at rest".Jim
Posted: Sun May 23, 2004 9:47 am
by Kissfan79
This one is of the throttle assembly with the gas peddle to the floor. The gap between the arrowheads is about 1/8" or so. I did notice with the peddle to the floor (someone actually having their foot on the peddle) if I touched the assembly, it basically "pulled" itself to the stopper. I think your right....that there is supposed to be that tiny bit of play at the end.Jim
