pre-ignition beeping-make it stop, MAKE IT STOP!
Posted: Sat May 15, 2004 2:57 am
by Zig in East Orleans
When first putting the key in the ignition, there's a v. loud beeping that happens (about 4-5 beeps). A. is this necessaryb. how can i disconnect it?
Re: pre-ignition beeping-make it stop, MAKE IT STOP! (Zig in East Orleans)
Posted: Sat May 15, 2004 3:11 am
by ragingfish
Is your door open when you put the key in?Is your seatbelt on?Closing the door and putting on your seatbelt before starting the car should yield no beeping at all.
Posted: Sat May 15, 2004 5:06 am
by NovaResource2
Quote, originally posted by Zig in East Orleans »When first putting the key in the ignition, there's a v. loud beeping that happens (about 4-5 beeps).Either your door is open and/or your seat belt isn't on.Quote »A. is this necessaryYes.Quote »b. how can i disconnect it?You can't. Close your door and put your seatbelt on before you put the key in the ignition and you won't have that problem.I'd also suggest reading your owners manual as this and more information is listed there. Hope that helped. Good luck and happy motoring!
Re: pre-ignition beeping-make it stop, MAKE IT STOP! (NovaResource2)
Posted: Sat May 15, 2004 5:42 am
ok, i feel stupidThanks guysI'm sure that'll work!
Posted: Sat May 15, 2004 5:46 am
by NovaResource2
Don't feel stupid, feel informed! I never put my seatbelt on first but I don't even hear the beeps anymore. I've learned to tune them out I guess.
Posted: Sat May 15, 2004 5:49 am
by scherry2
pull the audio warning buzzer
Re: pre-ignition beeping-make it stop, MAKE IT STOP! (scherry2)
Posted: Sat May 15, 2004 6:07 am
by ragingfish
Quote, originally posted by scherry2 »pull the audio warning buzzer Has anyone successfully located it? Even with the dash off I couldn't find it...I was thinking of putting in a quieter one...not so piercing..
Re: pre-ignition beeping-make it stop, MAKE IT STOP! (ragingfish)
Posted: Sat May 15, 2004 6:18 am
by NovaResource2
I don't think it can be removed. I believe it is a "black box" type item that does many things, not just the warning beeps .
Posted: Sat May 15, 2004 6:28 am
by ragingfish
Well, I pulled out the 'ol service manual. Appears it's part of the "multifunction alarm module." Even if your car doesn't have theft deterrent, it has that MAM block, and that's where it is.Oh well. No big.
Posted: Sat May 15, 2004 7:14 am
by scherry2
bummer nothing like the old days.
Posted: Sun May 23, 2004 2:13 am
by watts1371
If you want to "disarm" it, find the small black rubber knob on the driver's side door sill. It feels like a button and you'll notice that if you push it in, it tricks the car into thinking that the door is closed. If you like to run the radio while cleaning without running the engine, then find a way to keep that button pressed in. If worse comes to worse, take that button out and unplug the wires leading to it. The downside is that your "door" lights will not work when you open up the door. I did this with my old Honda. I guess it just depends what is more important to you.
Posted: Sun May 23, 2004 8:24 am
by pmh013
I think this is an American thing. As long as the door is closed, my car is quiet. I don't even think that it makes noise when my belt is off, just the flashing figure on the dash.Any Canadians confirm this? Or do I just have the stereo up too loud?
Re: pre-ignition beeping-make it stop, MAKE IT STOP! (watts1371)
Posted: Sun May 23, 2004 11:22 am
by Jahntassa
Quote, originally posted by watts1371 » If worse comes to worse, take that button out and unplug the wires leading to it. The downside is that your "door" lights will not work when you open up the door.Also, if you have the factory installed alarm system, or an aftermarket alarm system, i'd suggest not permanently disabling the door trigger, else someone would be able to open your driver door without triggering the alarm.
Re: pre-ignition beeping-make it stop, MAKE IT STOP! (Jahntassa)
Posted: Sun May 23, 2004 11:40 am
by ragingfish
Also, if you bypass that trigger, and you DO manually turn on lights (even without realizing it), you'll never get a warning when you leave the car...
Posted: Mon May 24, 2004 3:05 am
by drunkenmaxx
uh, my car beeps when i don't wear my belt???
Posted: Sun May 30, 2004 2:02 am
by watts1371
Yeah those are the downfalls, but if it really bugs you that bad to have it beeeping, disarming is the best way to get rid of it.
Re: pre-ignition beeping-make it stop, MAKE IT STOP! (drunkenvibe)
Posted: Sun May 30, 2004 3:07 am
by ragingfish
Quote, originally posted by drunkenvibe »uh, my car beeps when i don't wear my belt??? when you first start it, yeah.
Posted: Sun May 30, 2004 11:10 am
by pmh013
Quote, originally posted by drunkenvibe »uh, my car beeps when i don't wear my belt??? I listened very carefully the other day. It beeps about 5 times, then that's it. It's easy to miss! (I did)
