I have a question about the keyless entry Sys..
Posted: Mon May 10, 2004 3:43 am
by blk182@n7
On my GT I got a 3 buttom fob. the buttons are as follows lock unlock and hatch. The hatch button does nothing. Does anyone else have this issue? Should I take it in?
Re: I have a question about the keyless entry Sys.. (blk182@n7)
Posted: Mon May 10, 2004 4:06 am
by russ257
common thing, you have to hold the button in for like 4 seconds. its ok i thought the same thing when i got mine
Re: I have a question about the keyless entry Sys.. (russ257)
Posted: Mon May 10, 2004 4:09 am
by Sub-Vibe-R
Quote, originally posted by russ257 »common thing, you have to hold the button in for like 4 seconds. its ok i thought the same thing when i got mineRight, the harch takes 3 seconds to pop. If it does not, take it to the dealer, I've heard about some Vibe with the hatch selenoid not connected.
Posted: Mon May 10, 2004 4:10 am
by blk182@n7
kool i will check it out in a few min and post later . thanks again for the help.
Re: (blk182@n7)
Posted: Mon May 10, 2004 4:34 am
by rlong97150
Is that something that is only with the 03's. I could swear my 04 pops immediately.ThanksBob
Re: (rlong97150)
Posted: Mon May 10, 2004 4:57 am
Pretty sure the 04's function the same way.
Posted: Mon May 10, 2004 10:22 am
by PhiDelt
I have an 04 and mine pops as soon as I hit the button
Posted: Mon May 10, 2004 10:40 am
by blk182@n7
it took 3 secs then pop...outstanding
Posted: Mon May 10, 2004 12:46 pm
by SGT
I have a 2004 and tried this tonight. Window popped open immediately. No delay. I wonder if this changed from 2003 to 2004?
Posted: Mon May 10, 2004 12:54 pm
by NovaResource2
Quote, originally posted by russ257 »common thing, you have to hold the button in for like 4 seconds. its ok i thought the same thing when i got mineThey should really put that information in the owners manual.
Posted: Mon May 10, 2004 11:11 pm
by Jahntassa
It's the same way with most keyfobs I think. My fiancee's 2000 Grand Am requires you to hold in the trunk button for a few seconds before it pops.
Re: (SGT)
Posted: Mon May 10, 2004 11:50 pm
by wicked1981
I have an 04 base auto and poped open as soon as touched the button.
Posted: Thu May 27, 2004 1:43 pm
by 03VibeGT6Spd
Maybe GM change it after so many people brought them in for service. lolI have to hold mine a few seconds, It took me a few minutes to figure that one out.
Re: (03VibeGT6Spd)
Posted: Thu May 27, 2004 1:48 pm
I remember messing with a vibe at the showroom when i was getting ready to buy, and being like "geez, off the lot this damn car is already broken!" then the dealer's like "no, you gotta hold it down slick." i was like. oops.
Posted: Thu May 27, 2004 9:56 pm
by Jahntassa
Better than my experience Mike, where the fobs weren't even programmed into the car! I asked the guy if it would go into a panic mode if you held down a button, and we realized neither of the remotes worked! 30 minutes later they had them programmed.
Re: (Jahntassa)
Posted: Fri May 28, 2004 4:17 am
by drunkenmaxx
speaking of which, is there a panic mode?
Re: (Jahntassa)
Posted: Fri May 28, 2004 4:20 am
by Mr. Poopypants
Quote, originally posted by Jahntassa »Better than my experience Mike, where the fobs weren't even programmed into the car! I asked the guy if it would go into a panic mode if you held down a button, and we realized neither of the remotes worked! 30 minutes later they had them programmed.I had the same thing happen to mine.
Posted: Mon May 31, 2004 5:36 am
by Atomb
the matrix fob will work with my 04 vibe???how do you program the right freq. for my lock system?
