Got a question
Posted: Sat May 08, 2004 8:15 am
by bishc21
Ok, so i just got the car last week.. First time i wash it thru the auto car wash, damn moonroof leaks.. Not surprised and not really concerned since it all drains anyway, but I was wondering if maybe there were some way i could add some rubber weather stripping to the inside rim of the vibe's roof itself, like maybe the P-style weather stripping for windows and doors.. Its narrow enough to not overhang the rim and i would think it would add enough of a seal to compensate for the less than stellar one on the moonroof already. What do you guys think? Or should I just leave it alone and whine to the dealer?
Re: Got a question (bishc21)
Posted: Sat May 08, 2004 9:08 am
I vote for the whine to dealer, at least as a first step.
Re: Got a question (joatmon)
Posted: Sat May 08, 2004 9:18 am
by bishc21
probably will.. oh well. not surprised, just a quirk with this car.. but otherwise i love the thing to death.. its the best car i've owned!
Posted: Sat May 08, 2004 9:19 am
by pmh013
I also vote for whine. It shouldn't leak. If your windshield leaked, you'd definitely be PO'd. No difference in my mind.
Posted: Sun May 09, 2004 2:15 am
by ColonelPanic
Go whine to the dealer. My moonroof leaked pretty bad when running it through the car wash when I first got it. It also had a bit of water running in when it would rain.The dealer made some sort of adjustment and it has been OK since. You will see a few drops coming in from the right corner when at the car wash, but that's about it. The water goes down into the channel toward the drain, so it's not too big of a deal to me.See if they can adjust it a bit, and make sure it is draining if anything does enter the inside, and you should be OK. From what I gather, they can't make it 100% leak proof, the molding around the glass needs to allow for some flexing of the body that normally occurs when you're driving.
Posted: Sun May 09, 2004 3:21 am
by bus driver
Just got the Car? GO WHINE TO DEALER!!!!!!!!!
Re: Got a question (silverawd26)
Posted: Sun May 09, 2004 7:37 am
by Mavrik
Well don't go whining to the dealer lol just go in there and explain your problem. Its either a plugged drain or a seal thats not installed properly. Should be easy to fix without needing to sound like a child about it.
Posted: Sun May 09, 2004 11:11 am
by Mavrik
As a service advisor for GM at a dealership, I would love some WINE but hate WHINE.
Posted: Fri May 14, 2004 4:48 am
by Mr. Poopypants
Quote, originally posted by bishc21 »Ok, so i just got the car last week.. First time i wash it thru the auto car wash, damn moonroof leaks.. Not surprised and not really concerned since it all drains anyway, but I was wondering if maybe there were some way i could add some rubber weather stripping to the inside rim of the vibe's roof itself, like maybe the P-style weather stripping for windows and doors.. Its narrow enough to not overhang the rim and i would think it would add enough of a seal to compensate for the less than stellar one on the moonroof already. What do you guys think? Or should I just leave it alone and whine to the dealer?Don't worry about it, I took mine to the dealership and they explained that minor leakage may occur but there is a gutter inside the roof that channels water out if any water comes in. I was worried about this too, but it turns out, if this makes sense. It is by design.
Re: Got a question (Mavrik)
Posted: Fri May 14, 2004 4:57 am
by ArcsVibe
Make the cars better bro and they will stop whining! I always tell that to my brother at GM...as for the problem yes like everyone else says bring it in ASAP and let the dealer fix it.Please keep us postedSam
