Lowering 101
Posted: Fri May 07, 2004 11:02 pm
by 04BlkVibe
Alright..I'm interested in lowering my vibe..what should I know before i do that? What's the benefits of coilovers? Will lowering springs (such as eibach) ruin the struts that's in the car? as well, I've also heard that the tires will wear faster. Is this true?Let me know what I should know ...thanks!
Re: Lowering 101 (04BlkVibe)
Posted: Sat May 08, 2004 10:34 am
by goodvibe
If you go with Pro-Kits, TRD, Hotchkis or H&R you won't notice shock or wear problems after a front toe adjustment. Any lower than 1.5" drop and the risks get greater without different shocks and camber plates. Many go lower for looks but unless they're coilovers the ones listed above do the most for handling on the street where some wheel travel is needed.
