				Will these fit?
				Posted: Thu May 06, 2004 2:33 am
				by jayemright
				Hello,I found some 16"  225 / 7.5 / 50R Eagle Alloy rims on E-Bay that were on a Toyota Supra.  Will these fit my 03 Vibe?  ThanksJames
				Re: Will these fit? (jayemright)
				Posted: Thu May 06, 2004 3:06 am
				by AKLGT
				you need to find out the bolt pattern. the vibe has 5x100 mm.oh, ya... welcome to genvibe!
				Posted: Thu May 06, 2004 5:16 am
				by kostby
				The Supra is rear wheel drive, as I recall.  That could mean the offset is totally wrong.  The stock Vibe alloy wheel offset is about 35mm, I believe.  I've seen 'compatible' rims listed on tires.com and tirerack.com with offsets between about 30 mm and 42mmThe tire size 225/50-16 is slightly wider, but a compatible equivalent to the stock 205/55-16, so it wouldn't affect your speedometer at all.  If the bolt circle and the offset are in the ballpark you're probably in business.
				Posted: Thu May 06, 2004 5:53 am
				by frostyGT
				Both the newer and older style Supras have a 5-114 bolt pattern, so those wheels will not fit on the Vibe without adapters.
http://cgi.ebay.com/ebaymotors...=WDVW
