Tire Size Calculator
Posted: Mon Oct 07, 2002 12:02 am
by d_m_kolb
Tire Size Calculator Click here
Re: Tire Size Calculator (Admin II)
Posted: Sun Dec 28, 2003 10:56 pm
by goodvibe
Here's another SPEED IN GEARS calculator that's working. It's loaded with GT specs. Easily changed. http://www.car-videos.com/tool...ulate
Posted: Fri Apr 02, 2004 1:34 pm
by faygolovinjuggalo
thanks for the post.... man that really helped out... told me that my 225/40/18's are almost the exact same size as my stocks... -0.8% it really dont get much closer than that
Re: (faygolovinjuggalo)
Posted: Fri Apr 07, 2006 4:17 am
by Yoda
Quote, originally posted by faygolovinjuggalo »thanks for the post.... man that really helped out... told me that my 225/40/18's are almost the exact same size as my stocks... -0.8% it really dont get much closer than thatYou might also like 225/50/16 tiresGreat links BTW - especially the speed in gears. Thanks
Re: Tire Size Calculator (d_m_kolb)
Posted: Fri Apr 07, 2006 4:36 am
by Toasted7
That's pretty sweet... tells me that the 225/40-18 wheels/tires I'm lookin' at are nearly the same size as my stock 16s. That is very handy to know!
Posted: Fri Apr 07, 2006 5:12 am
by lextrix
I re-calculated (Speed In Gears) for my 235/45/17 tires...that means if I could get to redline in 6th I'd be going 183 MPH!
Re: (lextrix)
Posted: Fri Apr 07, 2006 5:20 am
by Raven
Woah! There's nothing like jumping 3 years and 6 months to confuse a guy.
Posted: Fri Jul 06, 2007 9:01 am
by bergse01
When using the tire size calculator, not sure if the math is being done correctly. In reviewing an explanation of tire sizes, the first number is width of tread, 2nd is hight of sidewall, and finally rim size. in putting in the stock vibe tire, and changing just the tread width to 275 (just messing around), it showed that my speedometer would show slower. to me that doesn't make sense. Just wanted to put that out there so people aren't relying on bad data.
Re: Tire Size Calculator (bergse01)
Posted: Fri Jul 06, 2007 9:05 am
by bergse01
screenshot of my results.
Posted: Fri Jul 06, 2007 12:23 pm
by Raven
The second number is the aspect ratio. It's in percent. 205 is the width in millimeters. The height of the tire from the rim to the tread is 55% of 205 or 112.75mm. A 275/55/16 would be 151.25mm high and being bigger would turn more slowly at 60mph and show up as slower on the speedometer which is calibrated for a 205/55/16 tire.
Posted: Mon Oct 01, 2007 9:47 am
by WaveAction
here's my results
Re: (WaveAction)
Posted: Mon Oct 01, 2007 11:30 am
by Kamikaze
This leads me to a question...If the factory size 16 is 205 55 16 &a factory 17 is 215 50 17...does that mean that my speedo is setup differently than a vibe with factory 16's?if so, then that would make sense on why I would go with a 235 40 18 instead of a 225 40 18...As you can see, the Diameter is off by 1/8" meaning I'll be traveling faster if the speedo's are the same...
Posted: Fri Feb 06, 2009 10:40 am
by CAN-AWD-VIBE
this is a good thing
Posted: Tue Apr 28, 2009 4:53 am
by HighMileVibe
Keep in mind, many speedo's are designed to be reading 1-5% HIGHER than actual. You can check yours against a GPS. Thus, a taller tire may actually make your speedo MORE accurate than with the stock tire size. It also effectively raises the final drive ratio for possible MPG improvements. Again, any MPG comparison would need to take into account the speedo correction factor (GPS calibration) to be a correct comparison.
Re: (HighMileVibe)
Posted: Fri May 08, 2009 11:30 pm
by HighMileVibe
Here's another calculator that you can save to your PC and run from MS Excel or OpenOffice (www.filehippo.com)The offset worksheet is a draft, the tire size is pretty well tuned and gives you 4 tires to compare at the same time.
Attached files wheel_tirecalculator.xls (26.5 KB)
Re: Tire Size Calculator (goodvibe)
Posted: Tue Sep 07, 2010 6:51 pm
by chrishil
Wow this is nice. But to some point, people does not normally compute the size of their car's tires.-------------------------------------------------------------------------------------wholesale parts
