I can't get my sig to show after i updated it? What gives???
Posted: Wed Apr 21, 2004 11:33 am
by ALi3N
My sig used to show just fine but i just updated it and now it won't show up. it should say:Stanten 'ALi3N' Meyer A.K.A. Dj ViP3RLatest mix download (mp3):http://ftp.shlrm.org/djvip3r/Live From Nowhere 404 (128).mp3 http://shlrm.orgPimpin' Vibe GTAbyss w/ MONONav & 17"What's up with it?
Re: I can't get my sig to show after i updated it? What gives??? (ALi3N)
Posted: Thu Apr 22, 2004 12:25 am
your sig shows up in your profile http://forums.genvibe.com/zero...=1462Did you change the setting in your user options to not include signature by default? Also, when you create/edit a post, there is a line above the POST button that says "Append my signature to this post" You need to have that box checked if you want your signature to show up. Inclusion of signature happens on anindividual post basis, you can show it in some and not in others. Setting the option in the user options screen just affects whether the box gets checked automatically or not. you can turn it on or off for individual posts if you want. try another post, make sure the box is checked.
Re: I can't get my sig to show after i updated it? What gives??? (joatmon)
Posted: Thu Apr 22, 2004 12:52 am
by ALi3N
Ok, now that i have checked the box, will it automatically check the box in the future?
Posted: Thu Apr 22, 2004 1:37 am
follow the "My Profile" link at the top of the page, go into "user Options", and there is an item for "Append My Signature by Default" that allows you to set the default. If you set it to append, the box will be checked by default. If you say Do not append, the box will come up unchecked by default. just checking or unchecking the box in one particular post will not change the default setting
