				A/C--Defrost Question
				Posted: Thu Oct 03, 2002 2:58 pm
				by Vibe
				Hey Group-- Help me to determine if this is normal---I had the A/C button on the dash turned off-Green Light not lite.  But when turning the selector dial to Defrost mode the compressor comes on but the Green Light -A/C on light still stays off even though the Def setting engages the compressor. I know the compressor runs during Def mode but is it normal for the A/C green light to remain off.Just need verifaction.  Thanks  James
				Re: A/C--Defrost Question (Vibe)
				Posted: Thu Oct 03, 2002 7:37 pm
				by NSimkins
				Yes, the A/C is always activated in order to dehumidify the air, which will help efficiently speed up the defrosting process.See:
http://forums.genvibe.com/zerothread?id ... =5229#5229
				Re: A/C--Defrost Question (NSimkins)
				Posted: Fri Oct 04, 2002 2:27 am
				by Vibe
				[QUOTE]Yes, the A/C is always activated in order to dehumidify the air, which will help efficiently speed up the defrosting process.        YES--I know that but my question is with the green light.
				Posted: Fri Oct 04, 2002 2:52 am
				by NSimkins
				Right, the green light basically indicates if the A/C button is pressed in or not.  If you have the setting on Defrost and have the A/C button off, then the light will not be green, but the compressor is still on.  The A/C button being on or off does not affect the Defrost as the compressor is always on in Defrost mode.Hope this helps.
				Posted: Sat Oct 05, 2002 12:04 am
				by Vibe
				Thanks for the info.
