MAgnaflow vs. Borla which is really the better gain?
Posted: Wed Apr 14, 2004 1:54 pm
by Celtic_Curse
OK now I'm in the market for an exhaust which has the better gain in hp and torque? Also on the magnaflow what exactly are you cutting off? I 've read the resonator but what is that and are you cutting off the catalytic? Anyhow didn't see dyno's for both on the search wondering if you all could help me out.
Re: MAgnaflow vs. Borla which is really the better gain? (Celtic_Curse)
Posted: Wed Apr 14, 2004 9:27 pm
by Triton
I've only seen the dyno from the MagnaFlow. Here is the chart that PTuning has on their website: As far as where you have to cut, you make the cut just in front of the stock resonator. It is after the sensor behind the catalytic converter. Here is a picture of the cut I made in mine.
Attached files Catalytic.doc (395 KB)
Posted: Wed Apr 14, 2004 11:27 pm
by celica girl
Why do you have to cut?
Re: (celica girl)
Posted: Thu Apr 15, 2004 12:36 am
by Psychobroker
because it's a true cat-back (not axle-back like Borla's), and the stock piping doesn't come apart in sections at that point, to the best of my knowledge.I'm sure Borla doesn't publish a dyno because theres very little gain. I don't think there's any way an axle-back will produce more gains than a cat-back.The only reason I see to buy Borla's is if you a) like spending more money for less gains, b) are a die-hard Borla fan, or c) like Borla's tip more than MFlows, but don't care that you could have gained 6 or 7 more horsies.Personally, I feel Borla's product description is false advertising, yet they refuse to change it. Unless they've changed it within the last two months, they still advertise their exhaust as a cat-back.
Re: (Psychobroker)
Posted: Thu Apr 15, 2004 2:04 am
by celica girl
I know what you mean... trd claims that their exhaust will give you an extra 14hp for the celica... which is not true at all... LOL.
Posted: Thu Apr 15, 2004 11:04 am
by Celtic_Curse
so you are cutting the catalytic off? won't that affect your car?
Re: (Celtic_Curse)
Posted: Thu Apr 15, 2004 11:07 am
by Raven
The cut is after the catalytic and before the resonator, so the catalytic remains in the system.
Re: (Sunny)
Posted: Fri Apr 16, 2004 5:50 am
by Thewhite
correct me if I'm wrong...from the engine, you have: the headers, the catalytic, the resonator then the exhaust.So you have to cut right after the catalytic, but on the Magnaflow it seems to have it. or it's the resonator?and if you cut, that's meen you'll have to do some soldering?
Posted: Sun Apr 25, 2004 11:23 am
by Celtic_Curse
so do you weld it on or clamp it on? Should I just take it to the shop and get it done professionally?
Re: (Celtic_Curse)
Posted: Tue Apr 27, 2004 2:24 am
by frostyGT
The magnaflow includes the resonator. After cutting, the magnaflow slides over the stock pipe and is clamped on. I did the install by myself, but it would probably be easier with a friend. The local shop wanted to charge me $100 for the install, but the whole job took me less than 1 hour. If you don't have a reciprocating saw, then you should borrow or buy one to do the cut. Also, spray the hanger mounts with WD-40 to help with removal.
Re: (frostyGT)
Posted: Tue Apr 27, 2004 2:33 am
by Kissfan79
How tight was the fit of the Magnaflow over the stock pipes after cutting? Was there much of a gap at all or was it a sealed fit?Jim
Re: (Kissfan79)
Posted: Tue Apr 27, 2004 3:40 am
by frostyGT
It was very tight...almost too tight! I had to hit it a bit to slide it over the stock pipe. The clamp is very strong, and compresses the new pipe a bit to make a very snug connection. No worries for me there!This is something that could easily be welded later if you had concerns.
Re: (frostyGT)
Posted: Tue Apr 27, 2004 9:46 am
by Mavrik
So your all saying then that Magnaflow is the one to go with? The gains look impressive, how is their prices?
Re: (Psychobroker)
Posted: Tue Apr 27, 2004 7:40 pm
by shibaman
I am partial to Magnaflow because I have had their mufflers on 2 cars. My 95 Nissan Pathfinder, and my Vibe. I had a muffler shop install a resonator , muffler , and stainless tip on my car. After I lowered it I had them remove the resonator because it was the lowest part of the car. At that shop they have cut aways of all the mufflers they install. Borlas and Magnaflows are a strait pipe with sound deadening material around them. The most restrictive part of the exhaust is the factory rear muffler. There is very little, if any differance in HP between Borla and a cat back Magnaflow. Both are strait pipes. I would buy the Magnaflow because of the sound deadening quailties of their muffs. You don't get sound reasonating into the car unlike other muffs.
Posted: Wed Apr 28, 2004 2:37 pm
by Celtic_Curse
Cool so Magnaflow is the choice of the group then? What about Greddy and such?
Re: (Mavrik)
Posted: Thu Apr 29, 2004 2:01 am
by Thewhite
Quote, originally posted by Mavrik »So your all saying then that Magnaflow is the one to go with? The gains look impressive, how is their prices?see my post at http://forums.genvibe.com/zerothread?id=9643if you are interested, but your name their, I'll had you to my list!
Posted: Tue Jun 29, 2004 6:29 am
by Celtic_Curse
Are there any quircks I should be aware of? Is there rattles and shakes?
Re: (Celtic_Curse)
Posted: Tue Jun 29, 2004 6:42 am
by AKLGT
why don't you just ask carrie. she has the magnaflow on her base vibe, ivan.
Re: (trdvibe)
Posted: Tue Jun 29, 2004 6:43 am
by VibeChick
Quote, originally posted by trdvibe »why don't you just ask carrie. she has the magnaflow on her base vibe, ivan. Good point Hope. And Ivan, you can drop by and check it out anytime, since you live, what, 10 blocks from me?
Posted: Tue Jun 29, 2004 1:01 pm
by Celtic_Curse
You Still have the restraining order remember...close as I can get is 5 blocks. Maybe I'll do that if no charges are laid.
Re: (Celtic_Curse)
Posted: Wed Jul 14, 2004 2:45 am
by Fialchar
When I had my exhaust system, I had a custom built 2 1/2" cat-back system welded on, then replaced the muffler with a Typhoon series muffler. I was pleased with the gains, and the change in exhaust tone.
Posted: Sat Jul 17, 2004 11:04 am
by Evanshall
cant you as well buy a high performance 3inch in/out magnaflow catylitic converter, which would as well help air flow!?!?
Posted: Mon Jul 19, 2004 2:07 pm
by Celtic_Curse
Be careful with pipe size 3" and up is usually reserved for V6 and up, not enough back pressure can rob you of performance.
Magnaflow Sound
Posted: Fri Jul 23, 2004 6:53 am
by cbetts
Does your Magnaflow sound pretty much like the sound from their web site? I want the performance without attracting too much attention from the cops. I like the sound of my Flowmasters on my Chevy V6 (4.3L) and hope this is about the volume of the Magnaflow on my Vibe GT. Any comparisons would be helpfull.
Posted: Fri Jul 23, 2004 12:38 pm
by Evanshall
if you have a GT, you will be able to get loader, but nobodies gonna hear you unless there relitivly close, it will be loader, but imbetween obnoxious(like fart cans for say) and normal, as the GT is already slightly loader then a average engine(atleast when it hits lift), in normal driving youll make little extra sound, in lift youll be a loader , but not "wow im def now" load
Re: Magnaflow Sound (cbetts)
Posted: Fri Jul 23, 2004 12:51 pm
by wicked1981
Quote, originally posted by cbetts »Does your Magnaflow sound pretty much like the sound from their web site? I want the performance without attracting too much attention from the cops. I like the sound of my Flowmasters on my Chevy V6 (4.3L) and hope this is about the volume of the Magnaflow on my Vibe GT. Any comparisons would be helpfull. It sounds almost the same as the Borla exhaust a little different but not by much.sound cliphttp://forums.genvibe.com/zerothread?id=8047
Re: (Celtic_Curse)
Posted: Fri Jul 23, 2004 4:56 pm
by Smokin' Rubber
Quote, originally posted by Celtic_Curse »Be careful with pipe size 3" and up is usually reserved for V6 and up, not enough back pressure can rob you of performance.All I got to say to the back pressure is show me proof or explain how back pressure could help teh engine in any possible way because so far none of the arguements I've heard for back pressure are convincing in the least
Re: (Smokin' Rubber)
Posted: Fri Jul 23, 2004 8:46 pm
by MadBill
Absolutely right, Smokin! There is a scientific basis for maintaining certain minimum gas velocities in headers and pipes (nobody uses 3" pipes for the primaries of the header for a 1.8 L. engine or 5" for the tailpipe.), but actual backpressure can only hurt by trapping burnt gases in the cylinder, thus displacing fuel/air mix and forcing the pistons to do extra work pushing them out. (as an irrelevant example, my first summer job at 16 was in a gas station. I watched their mechanic crimping the tailpipe almost shut on his old Desoto and asked him why. "I want to get better mileage and I figure if the gas can't get out, then it can't get in!" The next morning he was prying it open again because the car barely ran.
Re: (MadBill)
Posted: Sat Jul 24, 2004 4:12 am
by Smokin' Rubber
nice example MB
Posted: Mon Jul 26, 2004 2:30 pm
by Celtic_Curse
I'll see what I can do, I read it in an article and post the reason Other than that I finally did get my magnaflow exhaust and it sounds and works awsome.
Posted: Mon Aug 02, 2004 11:15 am
by Celtic_Curse
Now that I have it noticed a couple of things.1. Car sounds way cooler under acceleration and just idleing.2. when letting off the gas I occasionally get the phart put put sound. Is this common and does anyone else experience it?3. Noticed a slight rattle when I used to start it up, fixed it by making the resonator connection level, guess I put it on crooked the first time and now its gone.This is a great exhaust sounds so good and doesn't sound anything like those fart can mufflers you see the ricers with. Go get one if you can.
Re: (Celtic_Curse)
Posted: Mon Aug 02, 2004 11:17 am
by celica girl
I get #2.
