how does one get to the manual shifter linkage to lubricate it.
Posted: Wed Apr 14, 2004 5:18 am
by gogoputter
Anyone lubricated the 6 speed manual linkage? If so how do you get to it from inside the car, and what type of lube did you use.Thanks !!!
Re: how does one get to the manual shifter linkage to lubricate it. (gogoputter)
Posted: Wed Apr 14, 2004 8:13 am
by philndz
i used a lithium grease can w/ an extended straw on it and then hit some from above through the engine compartment and some from below w/ the car jacked up.....have someone shift through the gears while u do it too so u get all the parts lubed.-Phil
Posted: Thu Apr 15, 2004 12:03 am
by gogoputter
thanks...do you know how to physically remove the boot on the interior of the car so I can see what this inkage looks like?
Posted: Thu Apr 15, 2004 2:53 am
by philndz
ahhh, yes, i was talking about the mechanical linkage going into the tranny before but putting some lube on the linkage under the actual shifter is a good idea too.....its really simple....the boot has a wire around its base and is just held in w/ tension....just wiggle and squeeze it a little and it should pop right out.....it comes out easiest from the end closest to the parking brake.Make sure ur using lithium grease as it wont break down rubber bushings.-Phil
Posted: Thu Apr 15, 2004 10:20 pm
by gogoputter
thanks...I'll give this a try...
