ECU..Where?
Posted: Fri Apr 09, 2004 2:37 pm
by rcasciola
does anyone know where the ecu is located on the base vibe?
Re: ECU..Where? (rcasciola)
Posted: Fri Apr 09, 2004 2:41 pm
by AKLGT
the ecu is located under the glove box. you have to remove the glove box and a couple screws to get to it.
Re: ECU..Where? (trdvibe)
Posted: Fri Apr 09, 2004 2:45 pm
by rcasciola
i was reading in a magazine...that after you do some engine mods, its probably a good idea to remove the ecu for an hour or so to let it reset..it could give some hrspwr gains....any thoughts?
Posted: Fri Apr 09, 2004 2:52 pm
Just disconnect the battery. No need to remove the entire ECU.
Re: ECU..Where? (ragingfish)
Posted: Fri Apr 09, 2004 2:58 pm
by rcasciola
ha...how long would it take to reset?
Re: ECU..Where? (silverawd26)
Posted: Fri Apr 09, 2004 3:01 pm
by rcasciola
so...would it give it a horsepower difference????
Posted: Fri Apr 09, 2004 3:13 pm
by rcasciola
awesome... i think ill do that first thig in the norning:)
Posted: Fri Apr 09, 2004 3:33 pm
by GT_03
See, when i was modded my truck i got instructions to reset the ECU by disconnecting the Neg terminal and turning the key back for 15 seconds. It seemed to work in my truck, not sure if it applies here, just a thought.
Re: ECU..Where? (GT_03)
Posted: Fri Apr 09, 2004 5:43 pm
by AKLGT
when doing engine mods of any kind, you should ALWAYS disconnect the negative battery terminal!
