Oil Filter
Posted: Sun Sep 29, 2002 6:51 am
by myenvyvibe
Just wondered if anyone had changed their oil filter yet. I can't see to find any store that knows what filter to get. If you could let me know the part number that would be GREAT!
Re: Oil Filter (myenvyvibe)
Posted: Sun Sep 29, 2002 8:26 am
by NSimkins
There are quite a few now readily available and listed in the following threads with brand names and part numbers:http://forums.genvibe.com/zerothread?id ... ead?id=830
Posted: Sun Sep 29, 2002 9:43 am
by robodog61
Hello, I need oil filter info. also. There doesn't seem to be any answers on these threads. I have a Vibe base, 5 spd. I have a Toyota filter on it already. My mechanic gave me an oil filter with a slightly different part number. Does anyone know the correct Toyota part number? Thanks.
Re: Oil Filter (robodog61)
Posted: Sun Sep 29, 2002 9:52 am
by NSimkins
Well this is what I got from the threads I listed above:AcDelco: PF1233Fram: 4967 Toyota: 90080-91058 (base Vibe)
Posted: Mon Sep 30, 2002 12:18 am
by d_m_kolb
Amsoil Filters areThe Vibe part #SDF10The Vibe GT part #SDF10http://forums.genvibe.com/zerothread?id=2354
Re: Oil Filter (NSimkins)
Posted: Mon Oct 28, 2002 9:54 am
by MrMke
quote:Well this is what I got from the threads I listed above:AcDelco: PF1233Fram: 4967 Toyota: 90080-91058 (base Vibe)Hey Nick,Are the oil filters for the base Vibe and the GT one in the same?
Re: Oil Filter (MrMke)
Posted: Mon Oct 28, 2002 10:12 am
by NSimkins
quote:Hey Nick,Are the oil filters for the base Vibe and the GT one in the same?Depending on brand. I believe K&N uses the same filter for both engines as well as Fram and Amsoil. Toyota uses 2 different types:Oil filter for XR(Base): 90915-YZZA2 (shorter filter) for XRS/GT: 90915-YZZA1 (longer filter)
Posted: Fri Nov 08, 2002 11:07 pm
by Bdaz1
STP Oil Filter Part Number S4967 works (used in mine yesterday).
Posted: Sat Nov 09, 2002 12:08 am
by Vibe Rater
quote:Oil filter for XR(Base): 90915-YZZA2 (shorter filter) for XRS/GT: 90915-YZZA1 (longer filter) I wonder if you could use the GT filter in the Base VIBE?
Re: Oil Filter (Vibe Rater)
Posted: Sat Nov 09, 2002 10:16 am
by NovaResource
Yes. AC Delco only makes one filter for both.
Posted: Tue Dec 03, 2002 8:08 am
by Sam2Mar
Purchased a K&N filter for my Vibe last week.The part number is HP-1003 Better parts stores should be able to supply. quote:Just wondered if anyone had changed their oil filter yet. I can't see to find any store that knows what filter to get. If you could let me know the part number that would be GREAT!
Posted: Sun Dec 15, 2002 1:29 pm
by Pix Doc
Does anyone know if you can use the "longer" filter on the base engine?
Re: Oil Filter (Pix Doc)
Posted: Sun Dec 15, 2002 10:13 pm
by NovaResource
Adding a larger (ie longer) filter is never a problem as long as there is room and you add additional oil. For example, if the new filter holds a half pint more oil, you need to add an additional half pint to the engine.
