Air filter
Posted: Fri Apr 02, 2004 11:52 am
by pmh013
So, I took my Vibe in to the dealership today for the 105,000 km oil change. My air filter was getting pretty dirty (it's the original one), so they asked if I wanted it replaced. Yes, I would, thanks.Oh, we don't have one in.OK, I'll just run over to Toyota and pick one up. I had some other errands to run, and showed up at Toyota right at 5:30. Doors closed. Ugh.So, I went to Canadian Tire. None in stock. They called PartSource (basically a CT with only automotive stuff), and they didn't have one either.Question: how many limbs and first born children do I have to pony up to get a GD air filter?I will phone Toyota tomorrow and see if they have any in stock. If it's around $18 (which it was at CT) I will just have my finace pick one up for me on his was out of the city. If not, I guess I'm calling around to find the cheapest one & ordering it in.
Re: Air filter (pmh013)
Posted: Fri Apr 02, 2004 12:03 pm
by ragingfish
We talking engine or cabin?
Posted: Fri Apr 02, 2004 9:30 pm
by Caretaker
As of at least a month ago, Fram is already out on the street with a Vibe engine air filter.
Re: Air filter (ragingfish)
Posted: Sat Apr 03, 2004 1:55 am
by pmh013
I'm talking engine, but I've had the same experience with the cabin air filter.I ended up calling Toyota this morning. They have them for about $22 CDN. My fiance is going to pick me one up on his way home (he had to pull an all-nighter at work, poor (removed)).I'm sure they're out there as after market parts, it's just that the bozos around here can't be bothered to stock the parts.
Posted: Sat Apr 03, 2004 10:05 am
I checked my engine air filter and it looks fine. Cabin air filter is much more dirty.Thanks for the reminder to check the engine air filter.
Posted: Sat Apr 03, 2004 11:45 am
by MadBill
You should order a K&N drop in air filter from Canadian Tire. They are about $55.00 Can and will last you the life of the car. You just have to clean and re-oil it about once a year. It will also give you a small HP increase.
