VVTI question
Posted: Fri Apr 02, 2004 4:43 am
by Mr. Poopypants
OK, I know VVTI stands for Variable Valve Timing w/Intellegence. But what exactly does that mean/do?
Re: VVTI question (Mr. Poopypants)
Posted: Fri Apr 02, 2004 5:12 am
by ebslopp
Variable Valve Timing means that the valves can open and close at different intervals resulting in a larger power band. It was originally developed by Honda. You can see a really good explanation with diagrams at
www.howstuffworks.com
Posted: Fri Apr 02, 2004 5:13 am
by Stang2Vibe
It is Toyota's version of Honda's VTEC. It automatically controls spark and valve timing for maximum efficiency based on throttle demand. When you stomp on the gas, it tunes the engine to run for peak power, when you are idling around town or taking a lazy drive, it manages the engine to run at max fuel economy. This, in addition to what ebslopp said.
Re: VVTI question (ebslopp)
Posted: Fri Apr 02, 2004 7:18 am
by Mr. Poopypants
Quote, originally posted by ebslopp »Variable Valve Timing means that the valves can open and close at different intervals resulting in a larger power band. It was originally developed by Honda. You can see a really good explanation with diagrams at
www.howstuffworks.comNice find, thanks!
Posted: Fri Apr 02, 2004 11:44 am
by kostby
I don't remember where I got this from, but I think it was in a review of the Vibe GT...
Attached files VibeGTdescriptionofLifttechnologyDocument.rtf (2.5 KB)
Posted: Fri May 07, 2004 2:49 am
by SteveP
