HU Question
Posted: Fri Apr 02, 2004 3:42 am
by lumpcus
On my factory HU i have 2 separate wiring harnesses going into the back.. my new pioneer has 1 and then it has separate outputs for the speakers does this mean i'm gonna have to splice all my wires reattach them and so it can plug in?
Re: HU Question (lumpcus)
Posted: Fri Apr 02, 2004 4:54 am
by Fialchar
You can order wiring harnesses from different companies. Crutchfield has some and if you call them and give them the info about the HU/Car they should be able to send you one for fairly cheap.
Posted: Fri Apr 02, 2004 5:25 am
by Jahntassa
Go to your local Bestbuy or Circuit City and get part 80-2003 (from CC). I don't remember if the model is different at BestBuy. It should cost something like $17.Make sure you don't get 2003T, that's the wrong harness.If you had the Stock system, or the M&T system, you can ignore the second harness completely, you'll only use the large one. I would reccomend NOT cutting the factory connector, as that will only lead to problems later on.
Posted: Fri Apr 02, 2004 12:12 pm
The pioneer has two possible inputs: the RCAs and the main harness.When you pick up a harness, just connect the wires on the harness to the pioneer wires. I wouldn't reocmmend using the RCA inputs at this point in time since there is a currently unresolved issue with the amp...As Jahntassa said, just forget about that second harness that has only 1 wire coming from it. No one is quite sure what it does. Certianly doesn't appear to do anything important though.
Re: (ragingfish)
Posted: Mon Apr 05, 2004 7:28 am
by lumpcus
Thanks guys took all of 5 min to install once i got the harness.
