Pic of magnetic bra on 2004 Vibe
Posted: Wed Mar 31, 2004 1:44 am
by FusionFishGuy
Here is a photo of my recently installed Magnetic Bra on our 2004 Fusion Orange Vibe. It was relatively easy to install and cost less than a normal bra or the OEM one. It will not flop in the wind or let water seep under and damage the paint. So far, we really like it!! It should definitely help stop rock chips. Let me know what you think...
Re: Pic of magnetic bra on 2004 Vibe (FusionFishGuy)
Posted: Wed Mar 31, 2004 2:17 am
by 4X4CHICHI
I think it looks good, is it formed to fit the hood or can I just cut a piece of 4" wide magnetic stripping?
Re: Pic of magnetic bra on 2004 Vibe (4X4CHICHI)
Posted: Wed Mar 31, 2004 2:24 am
by FusionFishGuy
Quote, originally posted by 4X4CHICHI »I think it looks good, is it formed to fit the hood or can I just cut a piece of 4" wide magnetic stripping?It is cut out to fit the hood exactly, but the main thing that's needed is the trim strip that is provided with the bra. That is what fits around the edge and protects from vandalism. You might be able to get something like that somewhere else, but it is important to have.
Posted: Wed Mar 31, 2004 2:25 am
by FusionFishGuy
See http://www.magnetbra.com if you are interested in one of these for your car.
Posted: Wed Mar 31, 2004 2:58 am
by savedbyzero
That's actually quite nice! So does it lay completely flat? How thick is it? Is there just magnetic strips around edge or is the whole thing one big magnetic sheet?I need one of those! quite reasonable as well! Good find!
Re: Pic of magnetic bra on 2004 Vibe (savedbyzero)
Posted: Wed Mar 31, 2004 8:24 am
by FusionFishGuy
Quote, originally posted by savedbyzero »That's actually quite nice! So does it lay completely flat? How thick is it? Is there just magnetic strips around edge or is the whole thing one big magnetic sheet?I need one of those! quite reasonable as well! Good find! It does lay completely flat and molds water tight to the hood. It is only about 1/16" thick and is a complete magnet sheet.
Posted: Wed Mar 31, 2004 12:31 pm
by savedbyzero
Nice! I need!
Posted: Wed Mar 31, 2004 9:42 pm
by Reynoma
Very nice. If I didn't have my hood guard, I would consider one.
Re: magnetic bra on 2004 Vibe (FusionFishGuy)
Posted: Thu Apr 01, 2004 8:52 am
by jman66
Quote, originally posted by FusionFishGuy »It does lay completely flat and molds water tight to the hood. It is only about 1/16" thick and is a complete magnet sheet.The Magnetbra is nice but dirt and water will get under the edge over time. I have one on a 2002 Impala, just pulled it off to clean following the winter and there's a little dirt under it. But, nowhere near what would be under a traditional bar or mask. On my Vibe, had I not come across the Perfect Fit deflector, I would have put a Magnetbra on.
Re: magnetic bra on 2004 Vibe (jman66)
Posted: Thu Apr 01, 2004 9:16 am
by FusionFishGuy
Quote, originally posted by jman66 »The Magnetbra is nice but dirt and water will get under the edge over time. I have one on a 2002 Impala, just pulled it off to clean following the winter and there's a little dirt under it. But, nowhere near what would be under a traditional bar or mask. On my Vibe, had I not come across the Perfect Fit deflector, I would have put a Magnetbra on.jman66, have you had any problem with bubbles forming under the bra? Also, have you noticed a haze on the hood underneath the bra after you remove it? Just curious.
Posted: Thu Apr 01, 2004 11:14 am
by jman66
I have a couple of small "bubbles" at the left and right sides where the hood steps down. The Mbra does its best to conform to the shape of the hood and lies down well in warm/hot weather. Don't let my comments put you off, its a good product and protects the hood. No problem with the paint hazing under the cover. Just take the Mbra off once or twice a year, clean everything well and put a good coat of wax on the hood. Armor All works pretty decent on the exposed surface of the Mbra.
Posted: Fri Apr 02, 2004 3:26 pm
by sidewinder
So where do you purchase the perfect fit deflector I keep hearing about. I have the magnetbra but think I like the perfect fit deflector better. Thanks
Re: perfect fit deflector (sidewinder)
Posted: Fri Apr 02, 2004 9:11 pm
by jman66
sidewinder - i bought the deflector direct from the manufacturer: http://www.carbras.com/
