Help with install?
Posted: Mon Mar 29, 2004 10:23 am
by OutLaW
I would like to install small 6" neons under my dash. The problem is this. I need to be able to wire it to a positive wire. That's the problem. Only wire I know I CAN wire into is the lighter. Only problem is. I cant get to it. So the question is... Is there a way to get back of the lighter so I can get to the wires? Or if you can't get me to the wires. Is there a better suggestion to where I can get power from that won't cause problems. Another thing I don't wanna do it drill threw the fire wall. I tried to remove the panels around the shifter to get to the light but didn't wanna break anything. PLEASE HELP!!!
Re: Help with install? (OutLaW)
Posted: Mon Mar 29, 2004 11:12 am
by ragingfish
Real simple.Hop in the car.Go to Pep Boys.Pick up Littlefuse Add-A-Circuit: Remove the CIG fuse that powers your radio and associated accessories.Insert the red fuse into one slot on the add-a-circuit.Insert an identically-rated red fuse into the second slot on the add-a-circuit.Crimp your positive lead into the barrel crimp on the end of the pigtail.Connect your negative lead to a ground.Insert the add-a-circuit into the hole where the CIG fuse went.BAM!Two independent circuits.Problem solved!You can see how I used this device to add an auto-dimming rearview mirror: http://forums.genvibe.com/zerothread?id=7735#92046
Re: Help with install? (ragingfish)
Posted: Tue Mar 30, 2004 5:58 am
by OutLaW
I knew about this.. I was thinking of a harder way to do it. This is to simple for me.. Any other takers? lol.. J/K bro.. Thank you. Never even seen such a thing.. Does make things alot easier..
