Amp Help
Posted: Thu Mar 25, 2004 2:56 am
by lumpcus
Refer to this thread.http://forums.genvibe.com/zerothread?id=9181Buying a new system need enough power for 2 12" kenwood subs.
Re: Amp Help (lumpcus)
Posted: Thu Mar 25, 2004 11:56 am
by lumpcus
WOOFER FEATURES- Double Magnet Construction- Double Spider- Frequency Response: 25Hz - 800Hz- Impedance: 4 ohms- Magnet Weight: 63.4 oz- One-Piece Cone Design: with Red Metallic Center Emblem- Pearl Mica Injection-Molded Polypropylene Cone: 12" Typhoon-Type- Power Handling: 800 Watts- Sensitivity: 93dB- Speaker Connectors: Gold-Plated, 2-Way SB-Type- Urethane Surround: High-Roll, with Perpindicular Inner Wall- Vented Voice Coil: 2-Layerdoes this mean i have to get an amp that puts out 4 ohms also something that can put oout 800 watts?something like RMS:800x2 @ 4 ohms??
Posted: Thu Mar 25, 2004 2:01 pm
by Jahntassa
You're actually missing the most important number, a value called RMS. Knowing the peak power handling (800watts) doesn't help find an amplifier, as an amplifier with 1000 watts peak power might only put out 200 RMS.You really want an amplifier that can put out more like 300-400 watts RMS @ 2 Ohms, and connect the two speakers in parallel (positive to positive, negative to negative), that'll give you the most volume.Something like the MTX 421D might do it..
Posted: Thu Mar 25, 2004 3:20 pm
by cdFxer
Wow, is that sensitivity rating correct? In the communications world, 93dB is one heckuva "big" signal!
Re: (cdFxer)
Posted: Thu Mar 25, 2004 8:14 pm
by lumpcus
Quote, originally posted by cdFxer »Wow, is that sensitivity rating correct? In the communications world, 93dB is one heckuva "big" signal!That was taken from the Kenwood homepage..Thanks Jahntassa, that helps me out heaps!!
Re: (lumpcus)
Posted: Thu Mar 25, 2004 8:45 pm
by lumpcus
Alpine Accuclass-D MRD-M500Will this one be sufficient?
Re: (cdFxer)
Posted: Thu Mar 25, 2004 11:05 pm
by Jahntassa
Quote, originally posted by cdFxer »Wow, is that sensitivity rating correct? In the communications world, 93dB is one heckuva "big" signal!Yup, the 10" Sony P5's have a rating of around 92db I think.. Designed to put out more with smaller amps.And yeah, an amp that size should work well with two 12" subs.
Re: (Jahntassa)
Posted: Fri Mar 26, 2004 12:23 am
by lumpcus
Sweet, just put it on order..
Re: (lumpcus)
Posted: Sun Mar 28, 2004 8:34 pm
by lumpcus
tuut tuut, everything will arrive on wednesday! so excited!
