What's the little hole for near the gear shift?
Posted: Thu Sep 26, 2002 10:32 am
by jdf
What is the little covered hole near the gear shift? It is on the flat surface to upper right side from the gear shift. You can push it in and it pops back to the surface? jdf
Re: What's the little hole for near the gear shift? (jdf)
Posted: Thu Sep 26, 2002 10:35 am
by NSimkins
quote:What is the little covered hole near the gear shift? It is on the flat surface to upper right side from the gear shift. You can push it in and it pops back to the surface?That would be the Automatic Shift-Lock release button. (Automatic Transmissions only)If you refer to page 2-32 of your Vibe Manual, it will tell you how to utilize this feature.Basically, if you can't shift out of Park by depressing the Brake, you insert a flat-tipped tool into the slot and move the shift lever into the drive gear you want. (quoted some from the manual) On a side note: http://forums.genvibe.com/zerothread?id=369
Re: What's the little hole for near the gear shift? (Salsa!)
Posted: Thu Sep 26, 2002 9:28 pm
by yank dini
I read every manual for everything that I spend my money on no matter what it is. I think manuals are cool cause the salesman doesn't tell you everything and you learn something new everytime. IF YOU DON'T READ IT FOR ANYTHING ELSE, AT LEAST READ IT FOR THE GRADE OF GAS THAT IT NEEDS
Posted: Thu Sep 26, 2002 11:15 pm
by MA-VIBE-FAN
quote:What is the little covered hole near the gear shift? It is on the flat surface to upper right side from the gear shift. You can push it in and it pops back to the surface? jdfAlso, there should be a cover for the hole. Go back to the dealer and get one from them.
Posted: Fri Sep 27, 2002 12:29 pm
by Flip-Side
And here I though it was a straw holder, to go with the cup holder. Silly me
