Painting Calipers ?
Posted: Tue Mar 23, 2004 2:49 am
by blk182@n7
how is every one painting their calipers? what paint are you using?
Re: Painting Calipers ? (blk182@n7)
Posted: Tue Mar 23, 2004 4:12 am
by kaybeejay
If you paint them, doesn't that hinder their ability to dissipate heat thereby making them more prone to warping and other damage?
Re: Painting Calipers ? (kaybeejay)
Posted: Tue Mar 23, 2004 4:25 am
by blk182@n7
that was a second question.i really want the brakes on the GXP vibe
Attached files IMG_3144.sized (43 KB)
Posted: Tue Mar 23, 2004 4:31 am
by Reynoma
I'm using a G2 paint system purchased off ebay.
Re: Painting Calipers ? (Reynoma)
Posted: Tue Mar 23, 2004 4:51 am
by AKLGT
i want to get the gloss red paint... maybe next month... before i change out my winter/summer rims. but i hear teh g2 paint is the best out there.
Re: Painting Calipers ? (trdvibe)
Posted: Tue Mar 23, 2004 5:10 am
by Triton
I used the blue G2 kit that I bought off of Ebay. It was very easy and I have several pics on this thread:
http://forums.genvibe.com/zerothread?id=6177 Let me know if you have any other questions.
Re: Painting Calipers ? (Triton GT)
Posted: Tue Mar 23, 2004 5:13 am
by Triton
Here is a better pic with my new wheels on. You can really see the calipers through them, which was the look I wanted.
by Triton
And another pic:
Posted: Tue Mar 23, 2004 5:20 pm
by Stang2Vibe
Lookin' really good there, Triton!I bought a spray can of red caliper paint that I plan to use before I get the new wheels for my Vibe.I don't see how painting the calipers would cause any harm. It's the rotors that you want to dissapate the heat and they will warp if they can't do that. I've never heard of a heat warped caliper.
Re: Painting Calipers ? (Stang2Vibe)
Posted: Wed Mar 24, 2004 3:40 am
by GT-X
I use high temp. engine paint, $5 dollars a can. tape and spray, and they look good, granted I'll have to touch them up in the spring, but for $5 buck you can't go wrong.
Posted: Wed Mar 24, 2004 4:20 am
by blk182@n7
when you are painting them are you bleeding the brakes and removing the calipers?
Re: (blk182@n7)
Posted: Wed Mar 24, 2004 4:28 am
by Reynoma
Since the G2 paint is not a spray, you brush it on while the caliper is still attached.
Posted: Wed Mar 24, 2004 5:12 am
by blk182@n7
even better...thanks again i think i will get the red g2
Re: (blk182@n7)
Posted: Wed Mar 24, 2004 5:23 am
by Triton
I especially like that you don't have to mask everything off or worry about overspray on anything else. I would recommend getting a small model brush as well to get into the small places on the caliper. I used one and it was very easy to get into the tiny slots around the pads.
Re: (Triton GT)
Posted: Wed Mar 24, 2004 7:59 am
by GT-X
when I did mine I took the front caliper off and the pads out. then I put a plastic bag over the rotors and left the caliper sitting on top of the rotor and sprayed it. the rears I left them on and sprayed the paint into a dixie cup and brushed the paint on. It works well and its cheap
Re: (GT-X)
Posted: Sun Apr 04, 2004 2:25 am
by Mavrik
I painted mine with black engine paint that withstands a great deal of heat. I did not take the rotor and pads off, simply covered them with a large rag and sprayed away. Worked perfectly and looks good.
