Injen CAI Modified
Posted: Sat Mar 20, 2004 1:31 pm
by Bocaj77
If anyone has had a problem with the Injen Intake fitting on the Vibe because of the Fog light getting in the way I found that if you cut off about 2" of the tube it fits perfectly on the Vibe.
Re: Injen CAI Modified (Bocaj77)
Posted: Sat Mar 20, 2004 1:35 pm
by rasermon
It has been talked about, but I think your the first to trim some off. Post a pic and show us.
Posted: Sat Mar 20, 2004 10:56 pm
by Kissfan79
I had often wondered if that was a solution to that problem after hearing everyone talk about how close the filter comes to the fog lights. Evidently, it works . Wow...that would suck to cut off 2" of your CAI and find out it didn't solve anything or worse.....create a new problem.Jim
Re: Injen CAI Modified (Kissfan79)
Posted: Sun Mar 21, 2004 2:08 pm
by wicked1981
I had this problem and the solution from someone here was just push the filter farther up the tube. It worked.... No trimming needed.
Posted: Sun Mar 21, 2004 2:15 pm
I remember reading that altering or cutting the intake affects how well it works...and can cause power losses.
Re: (ragingfish)
Posted: Mon Mar 22, 2004 9:45 am
by redlava
Probably won't affect it if you cut off 2 inches. Probably just a warning to people who cut it off and make it a shortram. I know a few people in here have done that, hopefully with no side effects. I had a little problem with mine fitting, a little crooked, but with a little negotiating it went on.
Re: Injen CAI Modified (wicked1981)
Posted: Tue Mar 23, 2004 10:12 am
by Bocaj77
If you push the tube up inside the filter it causes turbulance and dosen't let the air flow smoothly.
