Need recommendation on performace brake pads
Posted: Wed Mar 17, 2004 10:17 pm
by Triton
I have just got some Brembo cross-drilled and slotted rotors and I am looking to get a recommendation on what type of perfomance brake pads to get. I definitely want something with low or no dust and no noise. Please post your ideas and links to websites if you have one. I would appreciate any input. Thanks!
Re: Need recommendation on performace brake pads (Triton GT)
Posted: Thu Mar 18, 2004 12:24 am
by Psychobroker
The ONLY a/m performance pads I could find to install w/ my BPI rotors were EBC's Green Stuff. Axxis might have an application now for the Matrix/Vibe, but up until a month ago they did not.
Re: Need recommendation on performace brake pads (Psychobroker)
Posted: Tue Sep 20, 2005 10:48 pm
by Pawel
Hey Psychobroker.What kind of rotors did you get? X-drilled? I'm looking to change my rotors but all I found so far were slotted ones and I want X-drilled. also, where did you get your pads?
Re: Need recommendation on performace brake pads (Triton)
Posted: Sun Oct 11, 2009 1:55 pm
by Sublimewind
Quote, originally posted by Triton »I have just got some Brembo cross-drilled and slotted rotors and I am looking to get a recommendation on what type of perfomance brake pads to get. I definitely want something with low or no dust and no noise. Please post your ideas and links to websites if you have one. I would appreciate any input. Thanks! I would recommend hitting up the major brake companies sites and going through the tech info.. I like the Baer Brakes site... You should also look at proper rotor seasoning and pad bedding as well as proper torque on the lug nuts. All will help extend the life of the rotors/pads... AFA pads, well, you honestly don't need much of a performance pad.. I used the EBC Ultimaxx pads and thought they where great, and I was doing some HARD driving in my Subie.. Tire Rack sells them, some digging and see what you find.. EDIT: http://www.tirerack.com/brakes...dClar=Lastly, I'm afraid to say.. unless you went larger in size on your rotors, you've actually lost some performance by switching to drilled/slotted rotors, due to less overall swept rotor surface area... In fact, it can make for some LONGER braking distances, because the brakes have a harder time keeping "some" heat in them.. Most performance pads need some heat to bite good... So if the brakes are constantly at a lower overall temperature, they have to heat further, faster, for the bite to take place.. I've run them, but i've also chased friends through the mountains of VT.. where I needed something more than a solid rotor could offer.. They do look nice, though, I must admit....
Posted: Sun Oct 11, 2009 2:17 pm
by ou.grizzly
It seems Triton has not been active for going on 3 1/2 years now.
Posted: Sun Oct 11, 2009 10:03 pm
by northvibe
hawk pads and stop tech slotted rotors may be the best setup as its cheap, good.I still find the drilled rotors worthless.
